Took delivery of my Exedy Heavy Heavy Duty Button clutch today. Hopefully the thing will allow me lots of fun with zero slip.
Anyhow I noticed the pucks are quite thin on their 'meat'. Not alot of room for wear (especially considering the rivets will start hitting well before the whole button is worn down)
I was wondering whether other brands of button clutches have thicker pucks.
Anyway, I took some picks to show how thin the material is, for those who might be interested.
I used the match stick as a reference, it was spare of the moment ok :cool:
Edited by Granthem
Had one of these in my car a while ago & although the friction material is very thin, it holds up ok.
Lasted 2 or 3 years in my car, thrashing the date out of it & only failed in the end because the pivot broke, the clutch fork moved & I tried to drive with no clutch... Very easy to drive with too. Overall nice clutch I think.
Due to the fact that you shouldn't slip it taking off (you'll get used to it...) it shouldn't wear a lot which I suppose is how you get away with such a thin lining. Haven't seen any other similar clutches to compare thickness
Yeht thats what I expected. The way its meant to be used I guess there isnt much meat needed. I was suprised tho, I expected a little more beef on the pucks. I was just wondering if any of the Xtreme clutches for example have more meat on the pucks.
I also bought a Nismo Pivot too... so that mine doesnt snap like yours, fingers crossed!
The nismo pivot is good security. I snapped 2 pivots which caused 2 buggered slaves as well & broke the pedal box once. Probably mainly to do with driving style but...
Grant is your part number nsk-7056HHDB? i have just had one of these installed last week.. and sorry to hijack your thread, but how the hell do you drive these things?!
are these button types definitely the ones you aren't meant to slip/ride? perhaps i should have gone cushioned button :)
Hey Ric,
Yeh thats the model! My old rooted clutch you see above was a cushioned button. It served its purpose well, I think 5 years of driving it took before it wore down like that. The killer for it was limiter launching at the drags on semi slicks.
As for the new button, you will get used to it! My mate has a twin plate nismo clutch and he can use it like a normal clutch, you wouldnt even know. Give it a few weeks, you will adapt to the severity of it.
Definitely dont slip or ride it. Basically learn the revs that it seems to engage with best, and you should be fine. You just cant get lazy with them... because they will snap your neck off if you stuff it up lol!
How much power does your car have? If it is a near standard 33 gtst, the cushioned button would have probably been a better option :)
yeah i'm hoping i get used to it.. the heavy pedal (my old one was feather light) already feels normal
car will soon be around 250rwkw, i'm planning to take it to the drags a bit so i think i've made the right choice as far as thrashability is concerned
Well yeh if that is your plans then I think you made the right choice.
My cushioned button didnt like abuse (althought it may have been on its last legs when I started the abuse, not sure)
Did you upgrade your pivot?
Definitely get the Nismo pivot, I've snapped a pivot but it wasn't as bad as the guy above, I was able to drive my car to the workshop by rev matching (it snapped at like 3am cruising home after some heavy abuse on a cruise) and didn't f**k the clutch or slave cylinder.
Well I got mine back yesterday. Its got some bite!
However, I dont think its too bad. I find blip to 2500-3000rpm and quick drop seems to get it off the line ok.
are you using the stock flywheel and did you need to get it machined or anything to clean it up?
I'm about to make a decision between the exedy HD Button like you have and a Exedy Racing Clutch Stage 1 sports ceramic, which is only $270 more....
http://www.kudosmotorsports.com/catalog/ex...23334-p-82.html
it's growing on me.. but i'm just a bit worried i'm riding it too much, even though i always make a conscious effort to get off it asap. is minimal slip ok or do i need to rev it up and dump every single time?
Im using a cusco chrome moly flywheel. It needed to be machined yes.
Yeh I know what you mean. Mine engages so quickly I dont think there is any chance of riding it really. It goes from nothing to grip in .0001 of a second. At the moment, im trying to get a hint of wheel spin off the line, therefore I know its engaging quickly. My tires dont "chirp", its more just small scrape of the rear wheels and Im off. '
Thats how I am making sure its not being 'ridden' on take off.
Should have gone for the 3 Puk Sports Ceramic for a tad more, there's more friction material and no rivots to worry aboyut.
I ended up getting the Sports Ceramic for a GTS-t using a R32 GT-R Push type pressure plate (rated at 1.1 tonnes).. and upgraded to a Nismo Big Bore Slave...
Car drives pretty easy
Just a small update... the clutch is well and truely worn in now. A few hard launches, hard changes etc.
I dont know if im getting used to it, or whether its just bedded in now, but its very easy to drive with. In fact, it hardly seems like a button at all.
Here's to hopeing its just me getting used to it... and not already losing its bite!
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
