All my instruments were playing up when i first got my latest S1. Speedo used to stick at a fixed speed - some instruments used to go to zero or maximum. I used to pull the bettery leads off and reconnect them and things would work for a while. It seems the connections at the back of the cluster dry out. I don't whether you can just pull the cluster out and touch up the connections with a soldering iron. Mine have stopped misbehaving for no apparent reason. Just to be sure though have a look under the car and check the speedo drive on the transfer box and the associated wiring
Speedo drive is in the transfer box (behind the gearbox) on the driver's side. It is electronic so wires go to ecu and up to dash. If you can get hold of (buy or borrow) an ecutalk then you can see if you are getting a reading at the ecu so you can eliminate the drive as a problem.
Hint: put your location in your profile so people will know if they are near enough to help you. (I'm probably not).
thanx kiwi for the tip
yeah had a look at the wire doesn't seam to be any damage to it
unplugged it and plugged it back in still not working
might have have to order one of those ecu talk cables next week to see if its a wire problem!
  • 3 years later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
