so,
problem here is, there is no experienced machinists in any sort of racing here in spain.
so i will have to attack this myself, so, when grout filing, how do i do it, do i just remoove all the lower core plugss, and fill heach one until it is about to reach to hole?, so i just do one? or do i do each so it fill equally? do i just fill the ones on he exhaust side, or take all engine ones out?
this car will be producing around the 800bhp and lots of revs, will this be any sort of handycap on the track with temperatures? not shure what ambien tems you get there in summer, but its around 30-35ºC here in summer
thanks
simon
  • Replies 44
I leave all the welsh plugs in as you will at least need to fill to the top of the lower welsh plugs. I usually replace them all with new stainless plugs after I have hot tanked the block before I hardblok them. You can buy hardblok as either a half fill (usually 2 small bags but sometimes 1 big bag) or you can buy it as full fill which is 2 large bags. Once the block is clean and welsh plugs in place the block needs to be upright and level preferably on an engine stand. Mix the hardblok to manufacturers recommendations in small batches as it goes off fairly quickly. I prefer to do the job with 2 people using a small funnel and some wire to help get it thru the funnel and then level it out at the bottom of the block. I just pour some down a water gallery at each cylinder then work it around with the wire. I just work my way around the block. Its best to bore/hone and deck the block a few days after it has set.
If a block is to be bored/honed using a torque plate or not then hardblok should be used before hand and same goes for align honing of the crank tunnel. If sleeving a 30 block I would probably fit the sleeves first then use some hardblok between the cylinders with the engine on its side with the welsh plugs out. Do one side then the other after the first side is hard enough to turn the block on its other side. The reason I do this is that the standard cylinders end up fairly thin towards the top of the block between the cylinders when machining to suit the sleeves and in some spots can break thru to the water jacket. By adding some hardblok in these areas can add some strength back into the block. Once that is done you can fit the welsh plugs back in and do a normal short fill or a full fill for an all out drag engine. You can then bore/hone the sleeves and deck the block etc.
oh, another question, how would a block / girdle brace compare to half block fill?
im very scared about filling up half the block and doing it wrong and ending up overheating every race meating
Simon...you only do up to the bottom of the welsh plugs...nowhere near half fill. Read what i have already written previously. Harmonic vibration and the added stresses of the front diff twisting them is what cracks the blocks....unless you can fit a brace that is stronger than the bracing and ribbing already built into an RB26 block then i really doubt how effective it could be.
  Swiper the Fox said:
Some of the circuit racers have commented that they have lower logged temps after grouting. When you really think about how a thermostat controlled cooling system works it actually makes sense.
It may have you running a few degrees cooler mate.
Edited by Swiper the Fox
perfetc, thanks swiper.
so how do you apply the block filler personally? do you take the welsh plugs out, or have a measured amout of filler and pour it through the top of the water outlets?
thanks gain
simon
thanks gain
simon
take the plugs out so you can monitor whats going on...leave the front one thats lower near the thermostat in. Mix up hardblock...using a funnel and some mig wire carefully pour small amounts at a time down the water jacket holes. You will have to use the wire to help it through the funnel and also work it around outside of the bores as it doesn't flow very well. Make sure block is nice and level and leave for a few days till nice and hard.
there is a couple of other little things i also do that are not particularly necessary but thats enough info to get the job done.
practice on another block is a good idea...especially one that has punched a rod out through the bottom that will only end up as scrap.
so do we know if any rb30 rods can come with pressure fed wrist pins? i only ask cause of a very tough 26 i seen stripped, was drysumped and the little ends were all f**ked. one had punched the bronze out of the rod and had hammerd the piston pin hole in the piston to the point bits of piston were squashed out like the little end..
to much tune-up there mate.
hi again...like ships in the night :P
Was Herman driving it? :mad::P
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
