This morning on my way to work the needle flick to the other side after I reved the rpm at around 4k or 5k, and it stays there, how weird.
I searched some pictures to show you what does it look like now。
can anyone tell me why it happened, what will this do to my car and what should I do now.
Thanks heaps.
Picture 1: This is how it is now
Picture 2: This is how is should be
https://www.sau.com.au/forums/topic/319775-have-a-look-at-my-gauge/
Take the plastic face off and turn the needle counter clockwise back to zero.
Sometimes if the needle revs up quickly enough, or far enough past redline, it can't make it back to zero since gravity is giving the needle a hard time going back up, and holds it down on the opposite side.
If its resisting, DO NOT push it otherwise it will be out of sync (which is a pain in the ass to re-sync). It should rest on that pin just below 0, and with the ignition ON it should hold at 0 by itself.
Edited by Nic_A31
Thanks mate for the advise and help! I'll do it tomorrow and will keep you updated
Just another question: Is this a normal thing to R33/skyline/any other cars?
Dunno what you mean by normal...
Its not common but its not exactly Christmas when it does.
sorry mate my English is not good.
What i was trying to ask is that has such thing happend on other cars? or like is it a common thing to happen on a 96 sports car?
Coz I'm abit worry that this will cause problem to the rpm sensor or related component and hence cause damage to the car。
Ah righto.
Its just as likely to happen on any car with a tacho.
Don't worry about damage, there's nothing wrong, this just sometimes occurs when the tacho climbs quickly and goes too far up...it can't cause damage in any way.
Thanks heaps mate, much appreciated.
By the way Cefiro was in my list when I was looking to buy a rear wheel drive car in NZ, but after coming to Australia it became almost impossible as there were not many around, but now I still love it, for it's shape and the fun driving it.
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
