  • Replies 53
nah, fully built, forged bottom end, head work, high volume oil pump.
Reckon i should be putting 6L in?
Last thing i want is it to lose pressure all up.
I ran 6.5 litres in my standard sump for 5 years. Thats both on the street and track.
what oil pump man ? and yeah 2l extra oil WILL save your engine. even with 5.5l mine would surge, 6.5 and no drop anywhere. with the high volume pumps and standard sump 6.5 is an absolute no brainer. have u ran yours down the quarter ?
edit this question is for luke, we all know about yours piggaz !! :)
Edited by mico
No idea on oil pump brand. Brought the car with the motor built. It's got 34 vspec 2 turbos which I wanna upgrade to -5 soon along with injectors etc. Then take it down the strip.
Ill start putting 6l in and go from there. :)
  • 3 weeks later...
Hey fellas im having this problem with my r32 gtr.
10-40 Royal purple
Stock motor, Greddy oil cooler.
put 4.80 litres in and its over the full mark just about the H
still getting droping down of pressure from 6 to around the 3 mark on my defi din gauges which arnt even 4months old.
Thoughts?
it's a good oil but stock motor yeah? how old? - just don't think 10/40 is thick enough for these old 26's. They need the Nismo/Motul 15/50 or Edge 10w60
imo, i'd try some Edge 10w60 and see how you go
I put some 10-50 in a month ago. I hated it, oil pressure stayed at 100psi for 5 min on cold start (this is in summer). Once warm if I give it a bit of stick I reached 100psi at 4000rpm. Car felt so sluggish, and cold start noise was much more prominent.
Dropped the oil and put old faithful 5-40 in. Oil pressure nice and normal and cold start noises gone.
It all comes down to the life the motor has had I reckon
would 10-60 be ok for a oil temp between 70-80 though?
yeah stock motor, 19 yrs old.
  • 3 weeks later...
it was purely because the oil cooler rapes alot of my oil.. Should have used my head more ... got a 16row oil cooler ofc its gna use least a litre.
Put 6litres in like u guys said and its totally fine now..... not one bit of drop even at 180kph at drags
just found this thread.
i noticed a bit of pressure drop especially in 1st/2nd, nothing alarming, but thought it odd.
those that have contributed to this thread a while back, how are you guys getting on with filling it to where you have??
on a stone cold engine, where is your oil level on the dipstick?
on a warm engine, say after 10-15mins after shut down, where does it sit?
im on a stock sump, jun pump, tomei baffle and head restrictor, i filled to just above the H.
but going by this thread, seems it may want to be closer to the hump than that.
ill put an extra 0.5ltr in and see what happens, cant harm anything a little extra oil on a pump like the jun.
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
