just found this thread.
i noticed a bit of pressure drop especially in 1st/2nd, nothing alarming, but thought it odd.
those that have contributed to this thread a while back, how are you guys getting on with filling it to where you have??
on a stone cold engine, where is your oil level on the dipstick?
on a warm engine, say after 10-15mins after shut down, where does it sit?
im on a stock sump, jun pump, tomei baffle and head restrictor, i filled to just above the H.
but going by this thread, seems it may want to be closer to the hump than that.
ill put an extra 0.5ltr in and see what happens, cant harm anything a little extra oil on a pump like the jun.
  • 1 month later...
  • Replies 53
whats to question?
i run a stock sized SUMP, and an uprated JUN oil PUMP
(not sure if you read it as stock pump and jun pump?)
anyone care to let me know how there doing running a bit more oil with your setups?
Edited by jimBNR32
I would say that they would be running more oil because they are smart. If you are running a stock capacity sump with a higher flow oil pump and you go to the track, I think that your pump will drain your sump. Hence, bigger pump = bigger sump
whats to question?
Piggaz was doing track days with an overfilled sump with no problems
he had a Jun baffle though and his N1 pump (that is no longer serviacable might i had :D) has a bit less flow then you
i ran around the streets for 6 months with 400RWKW and a JUN pump on a stock sump with no problems... Filled the sump to 6L
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
