Up for sale is my 32, had her for over two years and it has been a blast. Over turbo cars now and just want a hassle free daily.
Interested in trades for a civic eg or similar + cash my way
White, factory sunroof. Rego till Aug 10'
- 2lt 5spd manual, 202xxxkm's
- serviced regularly with only mobile engine oils every 5000km's & only shell v power ever used
- replaced gasket heads, cylinder heads, valve stem seals, head stud/ exhaust manifold, timing belt and seals. cylinder head machined. all done no more than 30xxxkm's ago. engine still very strong
- 90% of all water pipes and hoses replaced
- full turbo back 3" xforce exhaust
- hybrid replica front mount intercooler
- blitz bov
- heavy duty clutch
- nismo damper adjustable only suspension
- hks mushroom filter
- walbro fuel pump
- 8000k HID
- turbo timer
- fuel, oil & boost center gauges
- head unit & rear 6x9's
- alarm
- rear spoiler removed, welded and re-sprayed boot
- de-badged, gtr style front bar (will require repair/re-spray), factory type m side skirts and rear pods
Bad points:
* The vents wont produce air, front/rear demisters still work, so does the A/C.
$8500 ono offers will be considered, stupid offers will be ignored
CONTACT RAY 0432 720 004
https://www.sau.com.au/forums/topic/319803-1990-nissan-r32-gts-t-type-m/
  • 4 weeks later...
