i used these. went straight in no mods needed other then the injector plug.
these are about 950cc and idle perfect. can get smaller ones is you dont think you need that big.
injectos
Edited by wasnt me
injectos
Those won't fit an R34 unless you get an aftermarket fuel rail to suit the 14mm o-rings
I've just had my standard R34 injectors high flowed to 700cc (approx) by a place here in Adelaide - Japanese Motorsport organised it for me.
Haven't got the car running again yet, but apparently the OEM spray pattern is much better than the big single nozzle aftermarket injectors.
They had problems finding anything that would fit without modifying the fuel rail as well...
I have a set of 650cc siemens and they are 4 hole
Car getting tuned end of next week
read my tutorial on them in the tutorial section. they are a very simple install and would cost about 30 bucks in mods to make it fit.
I run the 600cc injectors in my neo with a Nistune running them and they perform faultlessly!
I may be selling mine soon if your interested as im upgrading (plans to run e85)
lol very lucky. must have been why they went straight in
Your profile says you have a 33 GTST. GTST injectors and GTT injectors are different.
When i emailed those guys to ask if they would fit an R34 they told me not without modification to the fuel rail or an aftermarket fuel rail.
yeah mate i now have a R34. those are the exact injectors that i used. what i found when researching for them was
anything that suits BA-BF XR6T will need the fuel rail to be packed out with a couple of washers which is no big deal.
injectors to suit FG XR6T are are straight drop in with no mods required other then the plug change. As 180or200 said
the standard fuel rail is 14mm. i found ebay sellers dont seem to know much about what they are selling so i wouldnt
trust them anyway.
Edited by wasnt me
trust them anyway.
I see, so the only modification needed is because of the height of the injectors?
Bosch EV14 NO fuel rail mods required as 180or200 said.
I guess this isn't general knowledge as yet? My workshop had no idea this was the case a couple weeks ago and I ended up getting my standard injectors high flowed...
your right not everyone would know about these. i have had mine in my car for a couple of months
now. imo these are the best option for upgrading NEO injectors. I think it was about $490 deliverd for
a set of 6. 950cc injectors. you cant go wrong.
Edited by wasnt me
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
