Possibly thinking about selling up the bits I have been collecting for my car the past year in order to put the money into a house. Put up any interest you have but I am waiting on a call back about a house so I might not sell so see how it goes. And before someone says to themselves why the hell am I posting this if im not 100% its because if i do need to sell up I will know who wants what and I can get money right away.
Power FC plus Handset to suit r34 GTT, Z32 AFM plus plug/wiring and near new 02 sensor for R34 GTT- $1500
Low km HKS 25/30 BB Turbo, All lines (Braided oil feed) HKS Actuator and HKS hard pipe (It's a short 90 degree elbow that goes directly onto the turbo snail) no shaft play and no metal missing off the blades. Will bolt directly to standard manifold - $1500
Power Enterprise Injectors to suit R34 RB25, bought off another forum member and done not even 5000ks. New O rings. Im positive they are 650cc but as I am not home for 2 weeks I can't check the part number. They are yellow if that helps - $600 (were over $1200 new)
Mint Just Jap turn flow cooler will all pipes and the additional one you have to buy, done about 10,000ks - $500
R34 GTT Manual set up. Clutch pedal plus master, Brake Pedal and Accelerator and foot rest. I bought a complete set up off a member not long ago and put that aside to do my car but I tracked down and bought this set as someone else I know was after some for a track car but he has since gone to an AM set up - $250
Giulian
https://www.sau.com.au/forums/topic/319834-eoi-am-bits-for-r34-gtt/
  • 1 month later...
Giulian
hi Giulian very intersted in your power fc shoot us a pm if you are going through with the sale
thanks
Jason
Hey guys, At this stage the sale isnt going ahead, fitting the new box tomorrow.
Will keep you both posted.
The injectors are direct fitment as thats what I wanted to buy for ease of install and to keep the bay looking standard, If a cop was to see a spaced up fuel rail or some differences they may take a further look lol. And if people think cops dont know what they are on about some do!
A mate was screwed over by a cop who knew what and where to look for pretty much everything. He has a pretty well hidden boost controller and other bits and pieces and this prick almost picked up everyone
  • 5 months later...
Hi Mate,
I'd be interested in the cooler kit when your ready to sell!
Sorry mate never saw this rep[ly, I know its a long shot but are you still after a cooler?
PM me
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
