Ok guys need some advice and/or help.
Ok, Im looking at either going high flow or bigger, say HKS 2830/35??? I know with the high flowed i dont need to change anything, bolt off, get it done, bolt back on. Are there any other say HKS turbos that will bolt onto the standard exhaust manifold or will I need to get one made up??(Which i can get done for literally nuthing!! wooo hooo)
At moment Im in the market for a cheap stock turbo 2nd hand in good condition just so i can get back on road for the moment, anyone have one laying around?? SYDNEY NEWCASTLE OR CENTRAL COAST PEEPS????
https://www.sau.com.au/forums/topic/31984-urgent-helpadvice-required/
A few of the HKS turbos will bolt up to the stock manifold, although where you will run into problems is with the water/oil lines.
2530 seems to be a great street turbo if your not aiming for big (~240+rwkw) power, or maybe a 2535.
Theres a few good threads in the Force Induction section on the 2530 and 2535's.
Remembering that a highflow stock item will be a direct replacement with no other modification needed to bolt back on.
J
15psi over 12months=blown turbo. OUCHIES
I've now got my old high flow if you need to borrow it until you get enough $$ together for something bigger and better. I'll PM you Brad.
OK, having gone thru some pain myselft with modding my skyline, my piece of advice is this.
The turbo is the holy grail of the power you get from your engine.
Depending on what you want to use the car for, will determine your power levels and turbo configuration. (ie Street, Track, Drag, Combo)
Once you choose your turbo, you build around it - Pistons, Rods, Bearings, Injectors, Cooler, ECU, Ignition, Cams, etc
(BTW I am talking perfect world situation - which never seems to eventuate hey)
Choose wisely and choose once.
Id be taking advantage of Mark's offer if $cash$ not there for you ideal setup (Very Generous of you Mark BTW - gotta love how club memebers help each other out)
And remember - once you up the ante on the turbo, you gotta look at the support systems and internals too - but I guess you knwo that hey !
Good luck Brad !
Good luck Brad !
Exactly right Brendan. We both have lost money on the standard turbo -> high flow -> larger turbo.
I'm heading down to woolongong to pick up the turbo for you today Brad. You can run your 12 or 15psi no worries on this turbo and it bolts straight up.
If i were going to spend money on a turbo i'd at least get a 2530.
Good luck, get in contact with me if/when you want to grab the turbo off me. I'm on the northern beaches.
Jay: It was in excess of $6500
BMan: Thats what I was talking to John about, we worked out what turbo, then built around it. The 30/40 is what we want for in the end with all the other stuff. Must say though, the Microtech LTX12 seems to be the best way to go for aftermarket computers, I reckon better than the Power FC!!!!! Apparently the combo will run good even with stock internals!!!!! But they will eventually be changed to after i got this all setup!!!!
Mark: You are an absolute legend !!! It is appreciated greatly!
I ended up going to Wollongong for you to pick up the turbo yesturday, its sitting in my car now.
I've got my car in for a service tommorow and will be working back late.
I'll PM you and organise something so we can get you back on the road ASAP.
Do a lot of research before jumping in and buying the wrong turbo - I hope lending you the turbo will give you more time to think it over and get a good price at the right workshop.
Brad,
FYI
There is a Microtech LTX12 computer for sale at the moment on these forums. Might be worth your time making a bid on it if its a bargin.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=32344
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
