I'm in the middle of a spark plug, and rocker cover gasket replacement. I noticed after taking out the coil cover, that the rubber lining on the edge was very hard. Parts of it have already broken off. Can I get a replacement seal for this? It was quite clean under the cover, and there wasn't much dirt or dust in there, so even despite the rubber being hard and brittle it was still keep stuff out. But now it's cracked into pieces of which I am missing that section.
post-63769-1273370718_thumb.jpg post-63769-1273370741_thumb.jpg post-63769-1273370761_thumb.jpg post-63769-1273370780_thumb.jpg
https://www.sau.com.au/forums/topic/319865-coil-cover-rubber-seal/
The seal on the coil pack cover from my old 33 got very dry and deteriorated over time as well. Was probably there to keep out moisture.
I ended up ripping the remainder of ithe seal off as it was peeling off very easily, and falling in around the coils whenever i removed the cover. vaccumed all that shit out, didnt need any of that falling in the chambers when changing plugs!
Having the coil pack cover without the seal is still better than not having a cover at all though. Will definitely keep out more dust and crap landing around your coils and plugs
I managed to find all the little missing bits that fell of my cover. So in the absence of being able to find a direct replacement (havn't called Nissan yet), I might try and glue it back on. Then some black silicone underneath should do the trick. My coil cover was doing it's job despite the rubber being dried out and cracking as there wasn't much dust & dirt around the packs and plugs.
Called Nissan today about this seal and was quoted $175! Uhh ok. They don't sell the seal separetly so you have to buy the whole coil cover itself which explains the high price. Looking like silcone is going to be the best bet I guess. Will checkout Clark Rubber. Maybe they got something that would be close enough.
