I have this problem with my 1997 R33 GTS25T, the battery keeps draining itself, Ive checked the terminals, checked for earth leaks etc. Ive even got a brand spanking new battery and still the same.....any suggestions ?
At the moment, I have to disconnect the negative terminal on the battery to stop it draining itself whenever I park it for an extended periods of time and that's a pain in the back side.
Any help is appreciated, thanks in advance.
Cheers.
Edited by SerenaM
https://www.sau.com.au/forums/topic/319886-r33-battery-keeps-going-flat/
I had the same problem with the light in the boot. I ended up putting my camera in there and recorded after I closed and sure enough - light didn't go out.
If you have a multimeter (or friend with one) that reads a few amps you can see how much draw is occuring the next time you pull the battery cable. It goes "in-line" between the battery cable and the battery to read how many amps are being drawn. If there is much draw at all - like 1 amp or more, with everything off then you've got something wrong.
Generally look for anything that is causing a drain on the power, alarms, lights etc. Try disconnecting them one by one or pulling the fuses that supply power.
I have the same problem with my 33
My boot light is not on
I have an aftermarket alarm
its odd though a few months ago I never had this problem
I left my car at the top of the driveway for about a month because I wanted to drive my 31 around
I decided to change back,
I knew my battery was going to be flat so I got it charged up by autobarn
put it in left it over night and it started no problem for a week it was fine then it just started with the
battery problems over night and sometimes I drive to work, park it at 9am and then go to start it at 6pm and it sometimes struggles to start
I think it could be one of a few things
Ground - wire could be loose or damaged not giving a full connection
alternator - might not be charging correctly or loose wire or needs new brushes
corrosion on wiring might need a clean or change
short in the system or bad wire
Got my mate at Autobarn to check the alternator
my alternator is charging at 14v and is working perfectly
he said that there might be a current leak in the system
also been told to take out each fuse one by one and test the connections with a multimeter
might have to try this
If I cant work it out then I will take it to an auto-electrician
Edited by DRFT-ME
nope. dud battery. if you leave a lead acid battery flat it will start to sulfate immediately, and after a few days it will be cactus. it will never hold a charge again after that, the capacity will be minimal compared to when it was new. replace it.
to thread starter with a brand new battery - you need a multimeter on 20 amp range in series with the negative lead going back to the battery. Only do this with the car off and no accessories running - it will tell you what is drawing current. tape the bonnet pin (for the alarm) down and arm the alarm. then disarm and see if it's any different. then start pulling fuses until you work out which fuses are causing your current draw and that will narrow down the problem. you can pull the fuses one by one seeing the impact on the meter and then put it back. and keep a note of which fuses dropped the current draw and the amount of drop. you can then work out what's responsible for sending the battery flat too quickly.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
