I have this problem with my 1997 R33 GTS25T, the battery keeps draining itself, Ive checked the terminals, checked for earth leaks etc. Ive even got a brand spanking new battery and still the same.....any suggestions ?
At the moment, I have to disconnect the negative terminal on the battery to stop it draining itself whenever I park it for an extended periods of time and that's a pain in the back side.
Any help is appreciated, thanks in advance.
Cheers.
Edited by SerenaM
https://www.sau.com.au/forums/topic/319886-r33-battery-keeps-going-flat/
I had the same problem with the light in the boot. I ended up putting my camera in there and recorded after I closed and sure enough - light didn't go out.
If you have a multimeter (or friend with one) that reads a few amps you can see how much draw is occuring the next time you pull the battery cable. It goes "in-line" between the battery cable and the battery to read how many amps are being drawn. If there is much draw at all - like 1 amp or more, with everything off then you've got something wrong.
Generally look for anything that is causing a drain on the power, alarms, lights etc. Try disconnecting them one by one or pulling the fuses that supply power.
I have the same problem with my 33
My boot light is not on
I have an aftermarket alarm
its odd though a few months ago I never had this problem
I left my car at the top of the driveway for about a month because I wanted to drive my 31 around
I decided to change back,
I knew my battery was going to be flat so I got it charged up by autobarn
put it in left it over night and it started no problem for a week it was fine then it just started with the
battery problems over night and sometimes I drive to work, park it at 9am and then go to start it at 6pm and it sometimes struggles to start
I think it could be one of a few things
Ground - wire could be loose or damaged not giving a full connection
alternator - might not be charging correctly or loose wire or needs new brushes
corrosion on wiring might need a clean or change
short in the system or bad wire
Got my mate at Autobarn to check the alternator
my alternator is charging at 14v and is working perfectly
he said that there might be a current leak in the system
also been told to take out each fuse one by one and test the connections with a multimeter
might have to try this
If I cant work it out then I will take it to an auto-electrician
Edited by DRFT-ME
nope. dud battery. if you leave a lead acid battery flat it will start to sulfate immediately, and after a few days it will be cactus. it will never hold a charge again after that, the capacity will be minimal compared to when it was new. replace it.
to thread starter with a brand new battery - you need a multimeter on 20 amp range in series with the negative lead going back to the battery. Only do this with the car off and no accessories running - it will tell you what is drawing current. tape the bonnet pin (for the alarm) down and arm the alarm. then disarm and see if it's any different. then start pulling fuses until you work out which fuses are causing your current draw and that will narrow down the problem. you can pull the fuses one by one seeing the impact on the meter and then put it back. and keep a note of which fuses dropped the current draw and the amount of drop. you can then work out what's responsible for sending the battery flat too quickly.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
