  • Replies 41
Since you are in Christchurch go see EFI
http://www.nzefi.com/
and ask then about remapping your ecu and a tune. That will solve your problem and see you through til about 300kw.
If you decide to get another ecu you will be able to sell your present one.
There are plenty of people who can tune a PFC but they are no longer made or supported so for an extra few hundred dollars I have bought a Link but that is for another day - the cheaper solution above will do everything you want - remove speed limit, adjust rev limit, fully tunable. And despite what anybody might say a good tuner can make a huge difference to how well your car goes (obviously a bad tuner can rip you off). I believe EFI do a good job but I am sure there are other good tuners in Christchurch.
You won't get any huge increase in power until you get a better turbo.
  ryan101 said:
Nistune, best bang for the buck
When you take into account the cost of another compatible ECU and the work required to install the daughter board, it's not quite as great as what most people think.
A Power FC can be had for $1000 with hand controller. Nistune is around $500 before ECU ($250+) and installation (~$250+).
From what I've seen, it's damn near impossible to find a 33 GTST power FC, let alone a working one for even close to $1000
Hell, if you can find me one for $1000 with hand controller, that has NOTHING wrong with it, I'll buy it now.
where are you getting the $250 installation cost of that much from? nistune themselves will solder in the board for $60. so including postage it will cost you about $80 or $90. plenty of workshops will do drive in/drive out tunes for $1000 or less including the cost of the ecu.
Try looking thru a few pages of for sale adds. They pop up fairly regularly and range in price from $800-$1500 which suggests to me you should be able to get one at around the $1000 mark.
Hmmm, looking at the Nistune website again it would seem that I have got their pricing a bit confused.
I was under the impression that they were about $300 more than they actually are. That markedly improves their cost effectiveness.
ok i have a price from NZEFI ( which is a good performance shop in Christchurch )
They put a re map board and chip and tune it for $987.50, with a front mount setup fitted $450 and fuel pump fitted for $300 ( walbro 500hp )
He said expect 280hp to 310 hp on about 10 or 11psi.
So for $1737.50 is this good power? because i need a front mount. But what about the fuel pump?
Also would it be cheaper to get a power fc and just get them to tune it on dyno for a few $100 or get a link and have no afm?
All you experts tell me what to do!
The chip and tune looks fine to me.
You don't need a front mount unless you are planning on a new turbo. If you are not and you can find an R34 smic for about $100 and install it yourself that will save you money and get you to over 200kw. If you want a fmic down the track then you may as well do it now and $450 installed sounds OK.
A new fuel pump is a good idea. You can buy one yourself from NZperformance or Redline for about $200 and fit it yourself or let EFI do it.
If you get the EFI chip then when you get the big turbo or RB30 it will still be able to cope with a tune at each stage.
If you are set on a replacement ecu now or later then you better do some reading and make your own mind up. Power FCs are getting harder to find and over here seem to be $1200 - $1500 with a hand controller. then you will need a Z32 afm as well. They are not supported by the factory but there is a heap of information on SAU starting with Paul's FAQ and EFI will be familiar with tuning them.
A brand new Link would be my preference - there is a plug in for your car, the factory is in Christchurch and EFI can tune those as well.
Consider a Tomei fuel pump over a Walbro, bit more expensive but worth it in the end. And if u do get one, fit it yourself, very easy to do.
The tune/chip sounds alright and front mount fitted for $450 is pretty good considering the headaches that you get with some of the kits, but as said an R34 SMIC will do you for that power, but if your gonna upgrade eventually may as well do it now, Bit of extra piece of mind knowing your charge airs a little bit cooler with a FMIC
they all sound good thanks guys but heres another option im thinking about.
i can buy a mines for $400
and then i can run around 12psi if i like.
would this be a better option because its so much cheaper? and what results would i get from it?
They also popup on ebay and other random places :blink:
No. A mines ecu would be just the same as the one you get from EFI except it wouldn't be tuned for your car. And as suggested above Walbro is cheap choice - do your own install and with the money saved buy a better pump.
Mate dont listen to people that never had MINES ECU.
I had two.
On one set up i ran:
(stock turbo) Exhaust, pod, apexi cooler, 12psi T, splitfire coilpack, Mines ecu, so on 12 psi i made 208KW Safe afr all 12s. If you want dyno graph PM me.
Other set up im running now is:
Hi flow turbo, fuel pump (left over from other set up) 16 psi T, splitfire coilpack, r34 SMIC, exhaust, 3 inch intake+pod, 220kw at wheels safely altho running a lil rich due to aftermarket fuel pump and me blocking off the blow off for flutter, point is, its all safe.
Mate, im telling you, do not listen to people that never tried one, ask people that had one, as they will all recommend one for basic mods such as yours. Dont do what i did: had MINES, went to PFC, wasted 1300 for PFC plus two tunes (3g all up) all to go back to hi flow turbo and MINES ECU.
Anyway, ill stop recommending it, but thats definately my opinion, coming from person that had 2 mines ecu;s.
  jordanlisa69 said:
and i am looking at a mines ecu also but i read they richen it up and make it even worse on gas so that its more safe for your engine.
And to adis, did you literally just buy it and plug it in and you had 200kw? or did it need a tune for your car? Because the mines comes suitable for a r32 and r33 but r33 has vct so it sounds like they would need to be tuned for your car on a rolling dyno or something?
You buy it, and plug it in, thats all. But you need to have basic supporting mods which are: FMIC, POD, EXHAUST, boost 10-12 psi.
You plug it in, and thats IT. But for your own sake and to prove everyone else wrong, take it to a tuner, and just run it for 80 bux to see your ARF, to make sure they are safe, like i did, for your own piece of mind.
And i found my dyno graph of first set up i had.
Here is the original post: http://www.skylinesaustralia.com/forums/Rb...es#entry4565873
Date: 30 Apr 2009
  • Split fire coil pack
  • Turbotech controller set to 12psi
  • Apexi cooler
  • K&N Filter
  • Full exaust
  • Greddy blow off
  • Mines ECU
  • Stock turbo, fuel and everything else.
Dyno graph:
Thanks a lot adis your helping me out a lot here.
For now i think i will get the mines because i can afford that now. And i will just run 12psi and see how she goes.
Because in the end if the mines doesnt suit my car then i can always sell it for the same price and no loss at all really.
If it works mint i will take it for a power run to check that its safe and wait until i can spend the big money.
The auction for it closes tomo so i will keep everyone in touch on how it goes!
Cheers guys!
Cheers guys!
If you lived closer, id let you try out mine.
But like you said, get it, try it, you will like it, after you like it, do a power run to see how much you are making and make sure its running safe ARF's and be a happy man like me. Hope your happy in whatever you do. If you end up getting one PM me with your thoughts. Cheers :)
ok guys i have the mines ecu in the car now. these are the problems..
idles at 1500 rpm and bounces around a bit.
stalls every time i come to a stop.
doesnt boost at all until around 4 to 4500 rpm, but shows its running 12psi from about 3000rpm.
splutters around heaps and doesnt feel good at all.
any reasons for this?
the guy said it came off a rb20det engine so would that make a difference?
