I only have one key and it is really worn, i have a spare blank that i got some time ago but for the $400 or so it cost me from nissan i dont want to have it wruined by using the old worn key to make a copy.
I want to know how to get my ignition barrel out so i can get the waffers out to work out the code of the key.
I done this my old honda prelude and it was qiute simple but i just cant work it out for the skyline, on the honda all you had to do put the key in turn it to the on possition push in a pin and pull out the key with the barrel on it.
You didnt have to unbolt it from the steering coloum to get the inner barrel out.
If anyone knows how to do this on the skyline your help is greatly appreciated.
https://www.sau.com.au/forums/topic/319921-r34-ignition-barrel-removal/
You can use a worn out key to trace a new key to be cut.
I did this two weeks ago, and the newly cut key comes out just as sharp (it wont be worn like the 'trace' key).
Not sure about the 34s, assuming it's the same as my Cefiro, it's a BITCH of a task.
Dash out, unplug alot of wiring around the steering collumn, and drill through / extract 2 security bolts.
My suggestion:
Use the worn out key to cut a new one, it'll be fine.
I have to admit im a bit of a perfectionist, some might say OCD.
But after having the honda key barrel fail prematurely, due to the use of a worn key and previous owners having to much sh*t hanging off their key chain. This cost $540 to replace the barrel so I'd rather have the nissan key cut properly.
When I replaced the honda key barrel, all i had to do was put in a working key, turn it to the on position, push in a lever and the key pulled out with the barrel on it (separate to the housing that is bolted to the steering coloum with the two security bolts that the heads break off when they are done up)
This enables you have the key barrel re-keyed in the event say a thief or someone has a copy of your key.
Ive done it on a honda, ford, holden, suzuki, so i would have thought there is a straight forward way to get the nissan one out.
I would just pull out the door or boot barrel but i would be pissed off if i go to the effort of getting one of those out only to find out it might not have the same number of pins as the ignition barrel ie. 8 points instead of 10.
I know if i got the current key i have copied it would work but i know it wouldnt be as accurate as getting it cut to code, when i replaced the honda key barrel i had one key cut to code and went back a week later to get a spare made, asked the guy to cut it to the code and he said nuhh it will be just as good on the normal copy machine. Just cos he couldn't be f**ked setting up the other machine. and i could see with my eyes that it was miles off let alone measuring the difference, you could feel the normal copy girnded the barrel so it went in the bin and i told the to do another one properly.
I like doing things right the first time and not having to fix stuff ups later cos it wasnt done right in the first place.
If anyone could shed some light on how to remove the barrel without geting out a drill, dremel etc to remove the whole housing i would be extremly gratefull.
Sorry for the life story, just trying to explain why i want to do it this way.
Like I said man, security bolts...the only way to get them off is with a drill...they don't have a pattern in the head for a screwdriver, they're rounded off.
Look up security / sheer bolts.
It's alot easier to get the door locks out...the boot lock is probably the easiest of them all.
The barrel is in with sheer bolts so it can't be stolen, so it shouldnt be "easy" to remove.
I still don't get why you think cutting a key is half assed, even give Nissan your VIN number and they can get a key already cut (if they have that VIN on index).
Cold chisel, bash a straight screw slot in the head, unscrew. Or you might need to drift it with a pin punch. But you definitely don't need to drill it out.
Depends what tools you can fit in there without taking the dash out, and depends how adjsutable the collumn is on 34s.
When I replaced the barrell on the Ceffy, on the bottom one I used the drill to unwind it by wedging the drill bit in between the bolt and the hole...but couldnt do that with the upper bolt, and not enough clearance for screwdrivers/chisels to get in there.
That is pretty much true, a key cutting machine only copies and cuts at whole number depths between 0 & 9 a slightly worn key will still register closest to the nearest hole number ie the correct code, if it doesn't the key won't work full stop.
They don't 'trace' around a key as most people think, there is a bit more to it.
Edited by 666DAN
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
