Hey Guys,
My car has been off the road for a while now while I have been fitting new exhaust etc etc
I fired it up last night and I have white smoke coming out of the exhaust and milky crap under my oil cap.
It isnt coming out straight away but away a tiny bit it starts. It isnt all of the time either, some times it will die down to next to nothing (this is all at idle).
There is no milk in the sump.
Checked the dipstick - no milk.
There is no milkshake in my radiator, only coolant and water.
I have checked the lowest part of my cooler piping, there is no oil (thought it might be the turbo seal).
I have my PCV blocked with my covers vented to a catch can.
My mods list is as follows:
RB25/30
Type A poncams
Wiseco Pistons
Stock Rods
JPC Stainless manifold
PSR 45mm Wastegate
GT35R 0.82
3.5" Turbo back exhaust
Front facing plenum from dahtone racing
Front Mount
Vipec V44 plug in
Techedge 2j1 WO2
Bosch 044 with 3L surge tank
Nismo 740cc Inj
Splitfire Coil Packs
Am using the shittest oil known to man for now, didnt want to put the better oil in until I have sorted the overfueling. 20w - 50 oil.
I have some fully synthetic 10w - 40 oil to go in.
Please help
PLEASE :P
Sitting in the car now with the laptop waiting to go :)
https://www.sau.com.au/forums/topic/319928-milk-in-my-oil-cap-none-in-the-sump/
This happened to my last car after a MAJOR thrashing followed by a long time sitting.
Nothing was blown but there was a significant amount of condensation trapped in the motor. I suggest a very good and thorough service before anything else.
Mine was fine after I serviced it and ran it at opp temp and driven for a while.
Yep, coz you've sat it for some time, the engine has had some condensation in it, and where does it condense?? the rocker cover so you'll see it in the cap, drive it for a decent run and it should be gone the next time.
Yeh that is what I am thinking. I pulled the catch can off, and have a small amount of hot water right could just near the 90 degree bend but none in the catch can.
I just checked the oil cap again, there was hardly anything milky compared to last time, I was quite impressed.
I have taken all of the catch can lines and everything off and think I will see how it goes with them off, will help get rid of it a little quicker I guess.
What do call a "good service"?
The car was not trashed in the slightest before it started to sit, it was babied and then just sat.
Did a compression test. Results were between 120 and 130 for all of the cylinders, so no drastic drops. I am not sure how accurate the gauge is, but surely it cant be out 60 psi :wub:
Yeah its just condensation. Drop the oil and change the filter and take for a good run . Some cars during winter that dont get a long enough run can do this as the oil doesnt get hot enough to burn the water/condensation out of the oil.
Cheers thanks guys.
The car was run for over two hours today and there is not a sign of milk under the cap any more :P
Nice new fresh oil and some time without the catch can lines on and there is no milk at all :)
Thanks again.
Similar thing happened to me while my car was off the road for a month.. Except the oil turned milky/caramel. Turns out it was condensation/rust in the motor. I bought 2 sets of oil/filters and changed them after around 5 min of idling, then put some Elf racing oil and its been sweet ever since.
Do a compression/leakdown test to be sure if you like tho.
you should see the inside of a motor that has only done short in town driving......it is full of condensation and sludge in all the corners and nooks and cranny's. Some of the sludge is like black putty. All vehicles need a good long drive for a few hours every few months or so.
Why do you think that semi trailers get big mileage [in millions of km] out of their Mack's/Kenworths etc, because they do haul miles not stop and start stuff
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
