I got mine done at;
Expert Injector Clean
3/56 Smith road
Springvale, vic
Cleaned, new seals, flow tested. $30 each injector. 6 injectors = $198 incl gst
Wow bit much. Got mine cleaned and flow tested with seals fir $20 each.
  • 5 months later...
Nah haven't...I get my shit done at Petroject...who are now Logicar...standard sort of price ~$35 inc. GST for reconditioning and flow testing.
Note that there is a difference between simply cleaning injectors (some mechanical workshops will just run injector cleaner through them or ultrasonically clean) and reconditioning them with new seals/filters/O-rings.
  • 2 years later...
Resurrecting an old thread just in case anyone else is googling the same.
I just had a set of injectors flow tested by Injectorsonline in Springvale VIC, good quick service at the right price, recommended. Worked great by post, too.
I got a quote from someone else at almost $40 each to test and service, which doesn't really make sense with a second hand set...
It does if you're buying top shelf injectors - basically renders the injectors new, all things equal.
Did injectorsonline replace o rings, filters and end caps?
Injectors online is same as expert Injector clean isn't it.....same address.
also here's a
Tip for fresh players...only ask for an injector test...as its only about 8$ each and quite often they don't need cleaning...I mean I had 6 tested and only one needed to be cleaned...all up cost me about 60$..If you ask them to clean them all they will whether they need it or not.and charge accordingly...I mean why pay to clean injectors that aren't dirty...
Spot on Artz, I was after just a flow test, not cleaning. I'm sure the price would have been different for a full clean.
Birds, I got them to visually inspect the supplied o-rings, all good.
If you're putting new injectors in, I'd be replacing the o-rings since they cheap as chips and even ones which look good could be on the verge of breaking down...
The time/effort involved to replace them once they're in the car is too much :P
As Simon said...O rings are like timing belts...they can look as good after 10km as they do 100,000. Considering they are like 50 cents each, it's worth doing for the peace of mind IMO. Hopefully you don't have any issues.
Always rmemeber too people, if you're installing your own injectors, put a rubber safe lubricant like Vaseline on the O rings so they seat properly in the rail and manifold.
you have plenty of vaseline laying around birds? :touch:
I didn't think Vaso was safe to use on rubberz... KY's the go. :P
Considering that the clean and test is half the price of new injectors in some cases, I know which way I would be going... Xspurt 1000's please. :)
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
