I got mine done at;
Expert Injector Clean
3/56 Smith road
Springvale, vic
Cleaned, new seals, flow tested. $30 each injector. 6 injectors = $198 incl gst
Wow bit much. Got mine cleaned and flow tested with seals fir $20 each.
  • 5 months later...
Nah haven't...I get my shit done at Petroject...who are now Logicar...standard sort of price ~$35 inc. GST for reconditioning and flow testing.
Note that there is a difference between simply cleaning injectors (some mechanical workshops will just run injector cleaner through them or ultrasonically clean) and reconditioning them with new seals/filters/O-rings.
  • 2 years later...
Resurrecting an old thread just in case anyone else is googling the same.
I just had a set of injectors flow tested by Injectorsonline in Springvale VIC, good quick service at the right price, recommended. Worked great by post, too.
I got a quote from someone else at almost $40 each to test and service, which doesn't really make sense with a second hand set...
It does if you're buying top shelf injectors - basically renders the injectors new, all things equal.
Did injectorsonline replace o rings, filters and end caps?
Injectors online is same as expert Injector clean isn't it.....same address.
also here's a
Tip for fresh players...only ask for an injector test...as its only about 8$ each and quite often they don't need cleaning...I mean I had 6 tested and only one needed to be cleaned...all up cost me about 60$..If you ask them to clean them all they will whether they need it or not.and charge accordingly...I mean why pay to clean injectors that aren't dirty...
Spot on Artz, I was after just a flow test, not cleaning. I'm sure the price would have been different for a full clean.
Birds, I got them to visually inspect the supplied o-rings, all good.
If you're putting new injectors in, I'd be replacing the o-rings since they cheap as chips and even ones which look good could be on the verge of breaking down...
The time/effort involved to replace them once they're in the car is too much :P
As Simon said...O rings are like timing belts...they can look as good after 10km as they do 100,000. Considering they are like 50 cents each, it's worth doing for the peace of mind IMO. Hopefully you don't have any issues.
Always rmemeber too people, if you're installing your own injectors, put a rubber safe lubricant like Vaseline on the O rings so they seat properly in the rail and manifold.
you have plenty of vaseline laying around birds? :touch:
I didn't think Vaso was safe to use on rubberz... KY's the go. :P
Considering that the clean and test is half the price of new injectors in some cases, I know which way I would be going... Xspurt 1000's please. :)
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
