is the genuine nissan 7.5w30 engine oil any good? i just changed my oil for this stuff on the weekend...but i have no idea how to tell if its doing the engine good! It's only $29.95 for 5L so if this stuff is alright then I'm going to be using it from now on :P
cheers
greg
https://www.sau.com.au/forums/topic/31995-genuine-nissan-75w30-engine-oil/
  • Replies 59
Its what nissan say u should use.
Nissan also say your car only outputs 185-206kw too. And they say the drain interval is 10000km :)
I wouldn't use it unless my car were stock. As it is, I pay more for some better stuff and change it twice as often.
Nissan also say your car only outputs 185-206kw too. And they say the drain interval is 10000km :rofl:
for the RB25DE the recommended drain interval is 15,000 km :bs!: i change it every 5,000 km, of course. on the bottle is says to change oil in turbo engines every 5000km. the only mods i have done are full exhaust system and pod filter so internally there would be no more stress on the engine than a stock one (i think?!). anyway thanks for all the replies :O
the mechanic who did my major service put in penzoil synth 15-40 in my car. my suggestion is not to use that oil as at mid rpms, say 3500+ on the highway, the pressure is real low. it seem that at that amount of constant revs (hume hwy) the oil either broke down/foamed badly or was to thick to drain down through the motor at speed the pump was putting it back at the top.
i'm about to head up the gold coast & i'll be changing back to helix 0-40 as the oil pressure was much more constant and stayed higher on the gauge
  • 1 month later...
I recently changed the oil in my r33 GTST to Penzoil Synthetic 15 - 30.
I don't know what sort of oil was in there before but the 15 30w hangs around the 2 mark on the pressure guage at idle and rarely above 4 on freeway driving. The previous oil would idle round 4 and be around the 5 - 6 mark at 3000rpm. Some people have told me its bad to have low oil pressure but can't tell my why other than the obvious NO OIL!!
cyphen, the oil pressures you mention sound about right. oil pressure of 2-3 once warmed up is perfectly healthy and normal. when warm mine idles at about 1
Greg, what oil do you use? On mine idle is a little bit less than 2, and between 2-4 when cruising, and up to 4-5 when accelerating. Maybe can even reach 6 on very hard launch.
    • Jap premium will be 100 RON. You should use 98.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
