Factory airbox + good panel filter.
Best performance money can buy - infact it's cheaper than a pod setup 9 times outta 10
Hate to ask a really obvious question here (yes, I searched).
How far can stock airbox + awesome panel filter actually go? Numbers suggested seem to be around the 250rwkw mark - Can they go further? Is there a general accepted value?
Asking for my own selfish reasons ofc - R34 RB25DET Neo if that makes any difference whatsoever. Would be nice to find out to help decide where to go re:highflow.
LOL BeEnAr we should have been boosting side by side for induction notes on the Princes Fwy inbound :)
yeah it would have been good but I had stock airbox and K&N in for GOR. Oh and just for sh1ts and giggles, since i've had the pods on, car no longer blows black carbon smoke out the back and it also feels more responsive in the right foot department. Might need to get it on the dyno and see if it's making more power.
I had no problem with the airbox except that the top crease in it was rubbing on the bonnet and has worn into it. That and I wanted sucky noises from my engine back. I like sucky noises...
according to that magazine sponsored by 3a racing....
its just like the motul oil gives beter performance to your engine and in the vid it clearly shows the fan being moved for different oils
If a company makes a good product what better advertisement than to prove how much better it is?
Its up to the companies ethics to skew the results but airpods being so cheap I dont see why the other companies dont challenge the results if they are so biased/inaccurate
All airpod companies would be testing their competitors' in their R&D department and they wouldnt be hiding the results if it was looking good for them.
Its how business works.
Here is the test results
http://www.3aracing.com.au/HTML%20Folder/I...Shoot%20Out.pdf
I use the stock snokle with a Apexi power flow and heat shield
I couldn't tell if it was better or worse but I can tell you I gain'd a few extra horses over stock at the dyno
So for me at least I was a happy bunny and will stick with this set up
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
