Who knows what a relatively low km's neo engine is worth? with or without the turbo.
If you want to sell yours. . . not much
If you want to buy mine. . . . Alot :)
Yours is RWD right? Then you should get anywhere from $1500-2500 depending what you include with it
Mine is AWD, so different block and sump is different, so limited market, either another stagea or a gts4 skyline.
If I buy yours I will also have to weld the front of your car onto mine to accommodate some front drive train action!
Yep mine is RWD, When I sell it I intend to sell it with everything. Turbo, AFM, POD, side mount and piping etc and maybe even the gearbox and tail shaft as well...
Slowly getting manual conversion bits, just trying to source a s2 RB30 block for the engine build
I noticed Envy Imports has a few RB30 blocks in stock when I was looking around the workshop: not sure whether they are S2 or not, since I wouldn't know the difference. Might be worth giving them a call.
an s2 block has the oil and water lines on the turbo side of the block already drilled with fitments, s1 does not
That relates to using a VL block
All R31 blocks have them
I need to get one as well. I have Rb26 head already
Is your car painted yet??
Nah not painted yet still looking like a panda! Been messing around with all the little things, solving that warm start problem. If all goes to plan it will be in the paint shop in a week or 2.
what turbos you thinking of running?
Hahaha, always one step ahead :)
Do you still have another manual center console getting around your garage?
