All some advice here please :wassup:
Getting a Stagea 25tRS-FOUR V (yes I know the auto, but
not all of us can afford the 260RS)
The engines the 25DET, does anybody have
details of the turbo (ceramic or not ??) and what
sort of maximum boost levels I can run without
screwing the turbo or ping
(used to have a VR4 and that ran 18lb no probs)
Once I get it complianced and registered, I would like
to do the std turbo things
1 - 3" mandrel exhaust, high flowed cat
2 - dump pipe from turbo
3 - decent intercooler
4 - decent boost controller - any suggestions guys/gals ??
https://www.sau.com.au/forums/topic/31999-stagea-turbos/
yeah that's my understanding too, except that post 98 cars are based on the 34 RB25DET NEO. All the standard tricks should work :P
Hope so...my stagea's gunna get a bit of work too...time for some unstockness
https://www.sau.com.au/forums/topic/31999-stagea-turbos/#findComment-643206
Duncan - that would be anti-stockness :P :P
michaeljquinn - RB25DET std turbos have a ceramic exhaust wheel - not good for anything over 12PSI.
Boost Controller - I can't fault the Turbosmart e-Boost (except that it looks ordinary) it does a great job !! Go for an EBC - not a bleedvalve.
Post pics of your Stagea when you get some.
I can't wait until we see some of these on the road !
https://www.sau.com.au/forums/topic/31999-stagea-turbos/#findComment-643362
if/when the race car is up to scratch, my Stagea will be getting a very serious destocknising. :D
Tony, I also thought they were only twin piston front calipers....so some nice AP racing 6 pots are a the *long* list.
Watch out b-man, my block of flats is going to hand your whale a spanking at WSID
(one day)
https://www.sau.com.au/forums/topic/31999-stagea-turbos/#findComment-644519
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
