I saw this and thought - Hey, why not organise a Go Kart Cruise with discounted tickets!
So - today there is a Scoupon deal for 50% off 2 go kart sessions. I've never been to this place before but at 1/2 price why not give it a go.
If you are IN then place a post here. The deal is only good for 24 hours - so till about noon tomorrow.
As long as we get at least 5 people today, I'll then coordinate a date and we'll cruise and go-kart. I'll post here if it is a GO then go buy your tickets. Otherwise I guess you can buy 'em and go on your own if you like.
details:
Scoupon Deal
Kartatak web site
(From the Scoupon deal)
Only $24 for 2 heart-pumping Go Kart sessions, normally $48!
The Fine Print
Valid Sunday to Friday
Valid from 12 May 2010 from 12 November 2010
Valid photo ID required for racers 18 and up
Racers under 18 must be accompanied by an adult
Highlights
Sydney's hottest indoor go kart track
You receive two 10 minute sessions on their awesome track!
Each Kart has a remote timing system to accurately time your best lap down to 1/100th of a second
Race against your friends and compare lap times - the winner gets bragging rights!
Power slide through corners on Kartatak's awesome "skid car" track
No bookings needed, just rock up!
https://www.sau.com.au/forums/topic/320004-go-karting-need-5-takers/
Guys, deal will be that you have to buy your own "SCOUPON" Deal. Then I will arrange a date for those of use that have bought them to meet up on a SUNDAY, maybe a little cruise and go karting.
My son is joining in so I think we have at least 5. I just got mine and is it really easy just enter you details and credit card. Looks like they send it electronically because it didn't ask for a mailing address.
Everybody, this deal is a Go.
Make sure you buy your tickets before the deal expires at noon tomorrow.
The just got new karts there too, they are alrite. was a bit powdery on drift track side when i was there however..
i should upload the videos i did there.. but cant be assed chopping them up yet..
they are also opening a new place somewhere near lidcombe too
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
