Wrecking a 1995 R33 GTST. Was involved in a pretty bad accident and alot of parts are damaged so its mostly only engine, driveline and suspension parts available.
Pick-up is available from Emerald, Victoria and i will post smaller items.
Parts -
RB25DET Engine - 125,000km - Comes with all ancilaries/belts/turbo/manifolds etc. Was running perfect when in the car. Is missing blow off valve, AFM, fan and engine mounts. Any inspection is welcome - $1300
Gearbox - Good condition - Has had the shifter cut for shorter throw - $1200
Excedy heavy duty clutch - Minimal use, still has factory marks on clutch plate - $100
Tailshaft - $100
Rear subframe with diff/axels/hubs/hicas/handbrake. Rear brakes removed - $350
Rear brakes with rotors - $200
Front brakes with rotors - $300
Front 5 stud hubs X 4 - $150 pair
Flywheel - $50
SMIC with pipes - $50
Black Rear bar - Paint in average condition - $100
Black Tail lights - $50 each
Rear Reo Bar (reinforcement) x 2 - $100 each
Black boot lid with S2 spoiler - Missing boot lock and light - $150
Castor rods x 2 - New urethane bushes - $50 each
4 x kings lowered springs, front and back. Back with KYB Shocks - Good condition - $250
Stock R33 GTST Cat back Exhaust - Perfect condition - $200
Also have these parts left over from other R33 wrecks:
Front Subframe - $40
S2 Door trims, have factory holes for tweeters - $15 Each
Radiator hoses - $10 each
Glovebox - $20
Auto Brake Pedal - $15
Accelerator Pedal - $15
Interior Carpet R33 - $30
Windscreen wiper stalk - $20 each
Boot trim, no carpet, few cracks which are unnoticable once fitted - $30
Turbo heatshield X 2 - $15 each
Windscreen washer bottle - $15
Seatbelt set - $40
Undertray stoneguard - $30
Turbo intake pipe - $15
ABS unit 1995 - $40
ABS unit 1998 - $50
S2 Passenger seat, small stain would be removable- $50
Automatic cooler - $20
Automatic shifter surround - $30
Aircon Condensor - $40
Centre console with Auto swich - $20
SRS passenger Airbag - $50
Airbag module - $20
Contact me Via PM or in this thread. Cheers
https://www.sau.com.au/forums/topic/320065-wrecked-r33-gtst-parts/
These the same door trims I offered to buy in your old thread?
PM me if you want to sell them...I didn't get any reply to PM/email/post in your old thread before?
Hey mate. I'm after the 4 x kings lowered springs, front and back. Back with KYB Shocks - Good condition - $250
Emerald is quite far, can we meet up somewhere closer to CBD?
Parts -
Tailshaft - $100
Flywheel - $50
Glovebox - $20
Seatbelt set - $40
ABS unit 1995 - $40
ABS unit 1998 - $50
Airbag module - $20
hey mate interested in the exhaust if you could contact me that would be good
Was just wondering if the smic with pipes includes everything to put the car back to standard?
If so, very interested! Let me know.
Cheers
Its just the intercooler itself, 1 joiner and the pipe which connects to the pipes in the engine bay. No brackets etc. Cheers
Im interested in the brake pedal and auto cooler.
What's the rubber like on the brake pedal? I need one for a rwc.
What type of auto cooler is it?
Rubber on the brake pedal is like new. It's the stock standard Auto cooler. Cheers.
Still haven't got any reply on the door trims???? I want them, but haven't heard anything from you.
Can you reply in thread if you still want to sell them or not? maybe i'm not getting your PM's or you missed my post.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
