Had a few offers which didn't come through.
Bump guys, may part trade for track car such as S13, 180, Laurel, Cefiro, Jxzxx, etc rego/defected? Doesn't bother me - car will be track car only.
  • 1 month later...
Hi SAU'ers.
Car: Nissan Skyline R32 GT-R
Year: 1992
Colour: Metallic black (looks super hot in the sun)
Drivetrain: Manual, Variable 4WD
Odometer: 98xxx
Power output: 269.4rwkw (Hi-Tech Dyno)
Rego: Till late June.
Mods: R34 GT-R Injectors (s/s casing), HKS pods, HKS cat back, s/s blitz front pipes, Cusco Zero1 coilovers 10kfront 8k rear spring rates (approx) which are great to ride on without bouncing all over the road no knocks or leaks what so ever, Work Meister S1 18x10 +13 all round which give the car a super tough stance, Nexen N6000 245/40's all round which offer a nice bit of stretch and these tyres hold the ground like sh!t to blanket 98% tread left, Car serviced every 3,000k's (every 3 months as I don't drive the car often), Running 14psi through bleed valve boost controller with no issues of boost spike, Nismo Ti gear knob, Nardi Torino steering wheel (all leather, suits the trim perfectly), Redline gearbox fluid (smurf blood :mad: ) put in maybe 2,500ks ago which won't need to be replaced for the life of the vehicle, transmax transfer case oil replaced at the same time, as well as a Excedy H/D clutch with custom 1,500kg pressure plate (easy hold 300rwkw), replaced rear main seal at the time of clutch swap and gearbox fluids change, Adjustable cam gears, Car received 100,000k service at 85,000k's (before I owned the car), which consists of water pump, timing belt, etc etc etc, dash lights, A/C lights, tripple din cluster lights are all blue however I do have all the standard globes to go with the car and if the buyer insists I can change them back, slight guard roll on the rear guards (too allow for the phat wheels) but no paint was cracked what so ever, perfect job. EBC Green stuff front pads with plenty of meat as with the standard rear pads, HID headlight kit
The trim is spotless on the whole vehicle, as with the exterior with the exception of a few tiny little defualts being a 18 year old car although is WELL ABOVE average. I am the 2nd owner of the vehicle in Australia and do currently have all of the import papers etc. I'm sure I have missed things about the car so should you have any questions don't hesitate to shoot me through a PM. I do love this car, and no I am not really in a rush if it doesn't sell so please save your time and my time and no low ball me, it is perfectly maintained, never tracked while I have owned it, it is the cleanest sounding RB26 I have heard ideling.
I am after $25,500 Firm.
Contact via PM or 0433830055.
Photos will be posted tonight once I am home.
(btw, can't actually beleive I am posting up this thread :( )
Thanks for reading,
Wayne.
awesome car champ just out of my price range though!!!!!!!!!!!!!!!1
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
