I presume you are talking about the tyre profile... the answer is the same as any other car. Broadly speaking lower profile = better handling, higher profile = better ride. Its entirely up to you how much comfort you are prepared to sacrifice for ultimate cornering performance. For me that means 235/45 on 17 x 8 rims [i have a set of slicks for the track] but if you want 20in rims go for it!
at the moment mine sits about 20-25mm from the guard to tire, but id like it to sit right 10mm to right on it.
currently have Nismo S Tune suspension setup.
is quite good. good mix of ride comfort and sport, wouldnt say track ready though.
Agreed.. hence the "S" in S-tune = sport.
Nismo do not do an R-tune kit for the M35 but you can get stiffer springs if you feel you need it
Mine has bit more distance from tyre to arch due to a lower profile (235/40's).
A 45 profile tyre with a suspension kit that lowers an RS/RX around 25mm is perfect.
OK then it matters what kind of Stagea you have. Mine is a S1 C34 and ride height (as defined by Ryan above) is 340mm front and 350mm rear. "Slamming" it to the ground is usually a cosmetic choice as it gives you stuff all suspension travel and puts extra wear on driveline components.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
