ok this is a huge post so just bare with me,
Location is Adelaide.
R33 parts are from a S1, RB25 DET
R32 parts are from a RB20 DET
R33 Boot Lip spoiler - $150
Full set of R33 mats - $100
Rear parcel shelf - $30
R32 GTR rear seats - $100
S1 front bar - VERY AVERAGE CONDITION $30
R33 Window washer bottles - $50 each
Complete Doors in red, drivers is damaged but has everything inside - $350
Silver Boot with wing - $100
Red boot - $100
Guards for the pair - $150
R33 dash - $100
Highflow 3" cat - $100
R33 Radiator - $130 damaged one $80
R33 Passengers light - $150
R33 Rear lights + center garnish - $120
Rb25 coilpacks - $120
Standard R33 suspension - $150
Tein R33 Coilovers, height adjustable - $500
Greddy FMIC + all pipe work - $400
2 SR20 Manifolds - $300 each
R33 castor rods - $100
R33 starter motor - $70
R33 Power Steering pump - $70
R32 Starter motor - $70
R32 GTR passengers seat, perfect condition - $250
R33 standard seats, small rip on drivers bolster - $150 pair
Silver R33 doors, good condition, complete - $400
A pillar interior piece - $30
S1 Grill - $30
Edited by JiN_MaN
  • Replies 54
R33 rear pods - $70
R33 complete boot trim - $100
Dash surround thing - $40 each
R33 exhausts
Twin pipes $350
Brand name Jap kaitamatiso (cant remember name) - $300
Complete R33 manual conversion without gearbox and clutch - $400
R33 uncut loom $120
R33 standard ECU - $80
R33 Cross over pipe + blow off - $60
Clutch - NEED to be inspected
Exedy - $200
Nismo - $200
Standard - $100
Flywheels - $100
R33 Airbox + snorkel - $100
R33 AFM - $100
R33 tray - $15
R33 BOV - $40
R33 Steering wheels
Good condition - $100
Average condition - $70
R33 overflow bottle - $70
Nismo steering wheel, no horn button - $100
R33 Rear end - $400 (no wheels)
R33 Engine Crossmember - $100
R33 sterring rack - $80
And that concludes about 1/2 of the horde of car parts 3 brothers and a father have collected in 2 years.
Edited by JiN_MaN
Do u have any side skirts?
Nope sorry
Hey mate can u pm me your number interested in your "Complete R33 manual conversion without gearbox and clutch"
Done and done
Hey,
3" hiflow cat, is this ceramic or metal core?
Thanks :banana:
I have no idea, if you can give me a clue of how to tell I can check and get back to you.
Hey Jinman, Tein Coileys good condition? how many k's? no sign of leakage?
Condition is fine, I didnt get to drive the car, but was reported to be all good
Unsure km's, I could speculate but would never know the true exact km's, no signs of leaks and the rebound/compress no problems.
Jin Man, no reply Re: Coil Packs yet! :)
Sorry I get sick of waiting for for 5 minutes to write back to people.
Sorry its, $120 for the coilpacks only, loom and igniter are a different sale and not included in the coil pack price.
Greddy FMIC sold
Edited by JiN_MaN
hey mate, can you pm me your number? i'm after the engine loom (inc coil + ign), ecu and air box + snorkel if you still have em.
cheers luke
Pm sent
still have the right front guard?> how much for just that?
pat
0 410644102
$80 + postage
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
