My rear right HICAS arm ball joint is stuffed and has lots of play, I have bought a replacement and had a shot at replacing it tonight but got stuck.
Basically I jacked the vehicle up popped the boot off the ball joint and got the shifter on the flat sides of it. Took a bit of a wrench but it cracked and I sat there turning it for ages. It was tight so I assumed I was undoing it but after 10 minutes it didn't seem to have really moved. Am I doing it wrong or is the pressure of the wheel holding the rod in there and there a trick to getting it undone?
Cheers :P
Edited by Rolls
what is the other side joint doing?? , i vaguely remember having to hold one side whilst i loosened the other (feel free to correct me if i'm wrong , it's been a while)
This is what I considered but a friend of mine who had done it on a R33 said I should only need one shifter, unless of course R32s are substantially different.
I didn't take the boot off the other one though so I couldn't see if it was spinning, will check that first if no one else has any other tips by tomorrow.
Thanks.
All good I got a mate to come around with his rattle gun and we figured it out.
Was correct assuming that you the rack is a solid bar that spins, so I have to use two shifters, one to lock the other side and undo it that way.
Car drives much better now without the rear end shaking, also means I should pass regency with no hassle.
Thanks for the comments anyway!
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
