Mine flew off at a high speed long dun down south... scared the bejesus outta me...
I hav left only the left one on. Coz i got stick intercooler you see!!!
I talked to my mechanic guy and he agrees that it would only help by giving more air to your brakes...
I think its cos the stock front bar looks a bit flimsy with out them...
Cant provide and structural rigidity, its held on by plastic bolts that snapped!!!
Hi Chino, if the tyres are rubbing on the plastic inner guard panels, then the car is too low. It would handle and ride better if it was the right height ie; higher. Plus by removing them you risk..
1. Slowing the car down, the aerodynamics were designed to have them in place.
2. Damaging the inside of the guards with rocks, stones and other stuff.
3. Damaging the wiring harness that is covered by the panels
4. Allowing dirt and then moisture to build up and be trapped in the areas covered by the panels, rust is next on the list.
5. Damaging the outer guards with the tyre, if it hits the inner panel what makes you think it won't hit the outer guard given the right combination of bump and steering angle?
6. Damaging the suspension mounts as there is not enough travel to soak up the bumps, it might be uncomfortable for you, but eventually it will crack the chassis in the loaded areas.
I have a few more if you want, but I suspect that may be enough.
my plastic inner guard ended up tearing itself to bits. The loft side is on and only has a couple of rub marks but the right side seemed to be alot bigger and once a plastic clip broke at high speed the wind pushed the inner gaurd onto my wheel and burned a hole in the damn thing. Then things were flapping and carrying on so yank...off it came :cheers:
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
