Brembo Calipers R35 Gtr
ok so lets start this as a new thread. $2300 shipped for the set to AU, paypal payment only + 3%.
e-mail or pm me. no lowballer, trades or any other then payment by paypal.
Right front caliper is scratched , rest are clean the milage on the caliper is about 500miles on it the car never made it for 1st inspection. if you have a mate in the usa who can pick them up from me do send me the info and have them bring cash for the pick up. After dealing with the problem of this.
[email protected]
do you have retainer pins, backing plates and pads for this or is it just calipers
I have the retainers, pins and caliper bolts as well the clips. I do not have the pads or disc's any more as they are sold.
Is that $2.3k AUD or USD?
Which state are you located in? (for local pickup)?
this is Sorry about that its 2300usd and my pick up addy is Encino (ca) 91316 = this is located in Los Angeles area.
this would be wayyyyyyyyyyyyyyyyy better for me if you have someone state side who can pick up from me :thumbsup:.
how long did they take to get off the car? do you also have the poor guys wheels?
If your asking milage its about 500 miles, I do have the vin # and paper work that I bought the car from the previous owner on it if this is what your asking ? if not please do clarify this.
keep in mind dealer list per the set is about $7000usd give or take discounts etc. but tihs is a one time price for these. !
  • 1 month later...
  • 4 weeks later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
