Hey guys,
I wondering how many people would be interested in a club day at the canberra hill climb?
http://sdmahillclimb.com/Start.html
Ive put the feelers out to see if they do private days for car clubs, and was hoping SAU NSW would be up for it.
Thanks
Andrew
https://www.sau.com.au/forums/topic/320195-hill-climb-day-in-canberra/
This is something suited for discussion at the AGM, you should come along :3some:
With only 19 days to go until all elected members (Pres, VP's Tres, Sec) have to step down, I don't think the current exec team will be making any bookings. The new exec team, well, thats a different story as they will be the ones managing all the events
I think it would be a great idea, we have a lot of trouble with getting available weekend times for our regular events like Wakefield Park and the Nirimba skid pan.
Can you check out the cost to book, recommended max number of entrants, and who can provide insurance/permit (hopefully AASA).
Try Jeno (in the general members section http://sdmahillclimb.com/Committee.html )
Tell him I said to reply quickly to you or I'll kick his ass lol
He should be able to tell you if they hire it out at least...
I will find out what we can do re: instructors in the cars etc.
Heres a copy and paste with out the costs of the options
$x per day where the SDMA organises and conducts a hillclimb or other event on behalf of the Hirer.
$x per day for the use of the asphalt circuit, toilet facilities, pit area and café area where officials are provided by the SDMA (Clerk of Course or Deputy Clerk of Course, Grid Marshals, Flag Marshals/Observers etc). All other organisation and services undertaken by the Hirer.
Max field of cars is 60, which is heaps.
No instructors or passengers are allowed.
No firm dates yet as they need a propper application from the club before they consider letting us loose there.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
