Can you possibly do write up on swamping internal part, is that hard to do ?..
where do you find V35 wrecks ... not that easy to come by in Australia surely
i just need stand by key, just in case my only one fails
Its very easy to do.
Just take out the small screw and pop the key open.
Once inside the bottons just come out as a complete unit.
There is also the small transponder chip at the base of the unit where the key is joined to the plastic casing.
It also comes out very easy.
Make sure when changing the transponder chip over you put it in the new key the same way it was in the old key .(it also is staight forward.
Hope this helps
Have a go and see how you go ,if you have any trouble just shot me a pm
And post on things like "find a part" , there are a few wrecks out there .
Edited by Cra-Z-Boy
key blanks with remote are $280-$300 each from me. you will need your immobiliser codes to program them. no code = dont bother.
how many do I buy?
As far as the codes go are they the numbers to do with the cars BCM? TomR33 gave me my pin number after i pulled off the kick panel near the ECU and gave him some numbers
or where else do i find them or get them?
yeah thats the BCM key pin code
Edited by Cra-Z-Boy
fine with me. I called nissan on that and its $350-$375 new. understand that these are not cheap but you did buy a $80k car and parts are not going to be cheap for it.
When I got my V35 it only had one key ,so off to Nissan I went only to find out I had to swap my kidney just to get one.
Anyway to my solution.
I got 2 used keys from a wreck of a V35 both have the 3 bottons
$80 with post
This may seem dear for 2 used keys but in the grand scheme of things it's not to bad.
Then I went on ebay UK and got 2 new uncut blanks for the X-Trail.
Costing with post to my door $45
They are exactly the same as the V35 keys .
I gutted the 2 used V35 key and put the inturnals in the 2 new X-Trail blanks.
Key cutting for the 2 new keys $14
Coding at Nissan for the 2 keys $45
So all up for 2 new coded keys
$184 :P
I made this a new post as I thought most might want to see the much cheaper
alternative for new keys
do u mean like ebay.co.uk ? if so why ebay UK ? and not just ebay.com
sorry if that is a stupid question :D
sorry if that is a stupid question :banana:
Yeah Ebay.co.uk.
And why, well they were the only ones I could find at the time on ebay world wide
and really $45 including post is cheap.
So after seeing what price chris can do the keys for , I still say 2 keys at just over half the price of 1
wins hands down :P:) and im always very happy when ever I can save a little cash
and hope this might save others some aswell
So are we talking 280-300 for a key or 350 to 375 now?
going over 300 is going to put me off considering ill still need to pay to have the key cut and programmed? or was that the price with everything done?
Im on the coast but a trip to bris is not that hard to make + I would also want to get my FM radio working so over AM....
Do you need the cars body number? im guessing the keys going to come over blank? just rock up to nissan or a locksmith to get it cut?
chassis number would help but the part number I put up is correct for 90% of the cars.as for getting nissan involved- not really needed UNLESS you need the key codes. (send me a PM.) radio is easy to knock over its time and parts for me.
  • 3 months later...
For those who live in QLD i have a friend that can copy any key.
Just got two keys cut and programmed for my V35. $185e or cheaper if more than 1 or group of people get together and he will come and do them all.
They are non nissan keys btw.
Dont need BCM code, just a current key and the car. If you are after details please PM me.
Cheers
  • 4 weeks later...
$80 with post
$184 :)
where do u find the v35 wreck???
do u get them form ebay.co.uk aswell
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
