I am very interested reading about this project.
Are those cam covers painted or powder coated?
hay mate, to tell the truth i dont know what is being done with the cam covers.
the engine is in the car and the ARE intercooler is bolted in position, pipe work has begun, the mercury welder is very neat, ill post up photos in a few days once it is done.
thumbs up
Edited by GOT04
The covers are painted in an awesome custom pearl blue colour, which is currently Mercury's signature colour for rocker covers. It's up to Jay whether or not he intends to keep this colour or choose another!
The engine is in the car and the piping is being fabbed and the rest of the gear is being bolted in.
Here are the latest photos.
1st photo is the spit fire coil packs
2nd photo is the turbo side of the intercooler with the bov on it
3rd photo is the ATI 1000hp balanced
4th photo is the custom serge tank with 2 x 044 pumps
5th photo is of the 4inch dump pipe an par gear box
to be correctly mod plated it needs to have padding anywhere near where the head can hit.
So if I was to use a metre/(0.9) length from the top of the front legs down to the floor, it obviously won't go the whole way...they won't whinge about that?
And i've found a few different types of padding available...does it have to be a certain thickness to pass?
the engine is in and received a run in tune.
on 20psi and rev limit set at 7100rpm the car made 492hp on pump.
there are 2 things that need to be changed before it gets a hard pump tune and that is the spring in the waste gate at the moment is a 7psi spring so the car is lazy on to boost, so it will be changed to a 14psi spring so then the car will make a lot more in the mid range and therefore would have more power to build off for the top end so it should make more up top. and the exhaust is all 4 inch but finishes off at 3 inch at the muffler. so a new muffler is needed also.
this engine is made to rev to 8500rpm, i dont think the tuner at mercury motorsport will take it that high just yet but i look forward to seeing what is to come on pump fuel.
thumbs up
Edited by GOT04
so it got the run in tune last friday and i had power play last saturday, here are some photos from the day at queensland raceway.
i lost 1 race out of the whole day to a spastic evo that mercury motorsport also built, i look forward to a serious tune and full slicks for a rematch hehe
Edited by GOT04
Looks good Jay and good to see whats gone into it so far. :)
Good to see Tessa and Trent are looking after you well.
By the way, didn't even know you and Tess were on here.
This is Matt with the 32 gtr tess was talking to you about and how i commented on your fb photo lol
Bit random ;)
Sould be good to see what the final power figure turns out to be.
Matt D
    • Definitely needs ceramic coat and fresh wax every week. And cats. Running with no cats is a (unt act.
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
