Upgraded ID injectors/fuel rail will see upwards of the 550rwkw it's already produced as well, still retaining the standard head...
We are looking forward to what we can get out of it before the new head goes on that's for sure!!
Traction will definitely be an issue for this car but it will be one hell of a lot of fun to drive!! :)
We (Mercury Motorsport) also have almost completed a JUN 2.7 stroker in an RB26 with an HKS T51 SPL turbo (also in a 33 GTST). Will be interesting to compare the two! :D
  • 4 months later...
What rear housing is on the turbo?
Seem turbo is lazy, 35psi is at 7250 rpm looking at the graph. Check just incase your wastegates are leaking, or a boost leak?
if all ok, id be looking for a small rear housing.
hay mate, its how its tuned, he has given me some drivability. there arent any boost leaks and def not going a smaller rear housing. if anything id go a bigger turbo like the GTX45r, it would be perfect! with the 42r i can short change at 6000rpm and it still hard on boost on the gear change so its very generous on its power band. first thing is first and thats to get rid of the borrowed standard head and put my build one back on. maybe look at a 900hp plus with it all on. which is just pointless anyway.
ta for having a think about it though.
  • Like 1
took it for a run before its got the bigger wheels and wider tires and before it gets this head work put in
did a 11.98 @ 138mph
had it on maybe 40% throttle in 1st and 2nd, any more and it spun and axle hopped then flat foot in 3rd and 4th. but its on the limiter over the line in 4th.
did this on 17 inch wheels so the new 19s will have me still changing hard over the line for more mph and the tires a a 3 year old federal 275, there shit. new tires will we be anywhere from a 305 to a 335 just havent brought them yet so cant tell ya.
  • 3 weeks later...
That is serious rubber.
PM sent.
  • 7 months later...
so how much power rwkw rear will drive can be made wit stock 26 cams - 3l block cam gears and full ported head wit bigger valves , 42r 1.01rear 1000hp
i have pair of timei 260/270 10.25mm lift but if stocks can make over 400rwkw ill keep them in, daily driver vl
gerry
Edited by chairman
  • 1 year later...
  • 1 year later...
    • I don't like the sound of that. No. I mean I actually don't like the way that they sound!
    • I'm rating the Michelin Pilot Sport 5's I currently have on my NC, they are great for throwing the thing around on the street, and handle great in the wet, the price is also reasonable  They are not as good as something like a RS4 in the dry, but, as it is a street car, the 5's are alot better for inclement and cold weather  I've found RE003's to be 5hit....
    • Just as long as it's not those putridly disappointing RE003s.
    • I had this same experience going from a set of no name tyres that were on a set of good wheels (Enkei RPFs) to some Potenza RE-11s (this was a few years ago). The wet grip in particular was so much higher that it was almost scary considering how dangerous the old tyres were in comparison. The expense of the tyres also made me want them to last longer so drove accordingly. Wife happy. So now she only 'lets' me buy some flavour of Brigestones...
    • This. All of this. I am turning >$300 into small particles inside 20k km, because I like to be able to roll around any 90° street corner at the speed limit. Would my car be more fun with cheaper tyres? Possibly. When I swapped out the bald AD09s for new ones, the change in the car was massive. The obvious one was being able to put the power down instead of lighting up into silly wheelspin. But the corollary of that was that the lateral traction went from being fun to fast. It was more fun when it was loose. But the corollary to the corollary is that if I need to dodge a child in the road or emergency brake to avoid the arsehat who has just tipped a GWM on its side in front of me, then I've got a much better chance of that manoeuvre coming off without unintended "fun" meaning that I hit something else, or the original target.
