  • Replies 127
Posted Images
@ Chris - Basically do the good old screw driver test on the sill. You'll see if and where its buggered pretty quickly. I found that mine had rusted through a couple of panels near the dog leg. I dont know if its common for them to rust out around the wheel arch. Mine looked like it had been dodegied up in japan.
Just be prepared - once you start digging you might find shit you dont want to deal with!
This car is in Holsworthy? and i didnt know?
Mine is one suburb away. If you need some ideas for what to do next lol
Also if you change your mind about pulling the engine i can help you do turbos in the car, its not too bad a job just takes a while.
Cheers Jeff! Would be sweet to catch up at any rate! The engine is definately coming out - I just seem to keep having set backs... My mechanic's father just passed so this week is out, and most likely next week as well... The gearbox is getting a freshening up...
Whats done to yours?
Quick update:
Due to the amount of driving I do I wanted a slightly more comfortable pew to park my fat ass on. I bought a pair of 32 gtst front seats and through the drivers in. Well, I am honetly uncertain if it is very comfortable - its hugely high compared to the gtr one. I think I'll be switching back to the gtr one soon.
Engine out update - 11th october. Box and engine will be out and the upgrade done. box is going to get a freshen up to. Will post pics and mabe a diy for pulling the engine and box.
I have been looking into a couple of options for seats. I would love to go with a VELO seat, but I cannot find a reclinable one (they're ADR approved).
All the other comfy quality seats are not ADR approved - well at least none that I have found. I wouldnt mind some of the OMP seats, but again I run into ADR compliance issues. I dont want to drive around with an illegal seat in the car as it attracts enough attention - and luckily I havent had any issues with the boys in blue since owning the car.
I had a commodore for a daily before and it bored the living crap out of me... I am willing to pay for a great pew to park myself on, just have been caught so far... I could be like you and buy a twin turbo supra to cruise around in :(
I'll find one soon I hope... I will enjoy it more once the engine is complete :)
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
