Hey people, im new to the forums and im a proud new owner of a r33 haha.. a mate of mine put me onto this site and said i should check it out.
anyways i have a question and im hoping sumone would beable to answer it for me. I have a A-LSD light on my dash,, its always on. Im just wondering what that is.. ive asked afew people and they cant seem to answer this for me haha..
Anyways this is my car :thumbsup:.. its got sum wicked power.. the last dyno it got 291rwkw.
Edited by MattyFlynn
https://www.sau.com.au/forums/topic/320274-need-help/
first check to make sure there is fluid in the tank in the boot, its on the right hand side of your boot.
It takes special oil. Castrol Transmax oil works well in there. when the engine is off it should be on the MAX level.
DO you have a aftermarket ECU ?
https://www.sau.com.au/forums/topic/320274-need-help/#findComment-5228040
Start reading my friend. http://www.skylinesaustralia.com/forums/R3...or-t268134.html
Safe bet is the problem lies in your aftermarket ECU (assuming this since you have 291kw) not sending the TPS signal to the ALSD ECU.
sweet, thanks for the info its helped me alot.
https://www.sau.com.au/forums/topic/320274-need-help/#findComment-5228994
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
