Hey guys im geting a pair of project mu rear shoes to change, has anyone done it before? if so is it hard? please let me know as ive never done them before, ive changed disc's and change pads.. but not rear-shoes chheers.
https://www.sau.com.au/forums/topic/320289-brake-shoes-on-rear-drums-r33gtst/
I;ve only changed the drums once, and that was froma reakly old and fcuked hub. They are the same as most other drum shoe replacement jobs....fiddly but not hard.
If you haven't done them before just keep careful track of the direction of pins and clips and the order you take them off. Remember to adjust them after the disc is back on so that they don't quite touch with the handbrake off. Its a good opportunity to back off the adjuster in the cabin and take the slack with the adjuster on the cables under the car.
BTW why buy aftermarket drum shoes? standard ones are perfectly capable of holding (or if necessary locking) the rears when adjusted properly.
You'll be fine. Just take your time and do one side at a time, so if you get lost you can refer to how it should be on the other side. And take note of the shoe arrangement with the leading shoe towards the front of the car and the trailing towards the rear. This will become clear on inspection. Just make sure you have a good set of side/diagonal cutters and needle and flat nose pliers. Also scuff the inside of the drum up with some emery/sandpaper. Good luck.
having same problem as you tried everything tightened everything and only little lock.
how much were project mu ones?? i found them to be $300 too much just for handbrake shoes...
iam looking for a set now and need some urgently. anyone have any info on other brands i can purchase please pm me cheers
Yeh i paid 300 sent to my door, should get them today... , im doing 100km + entrys , i want my handbreak to lock up good for good entrys, how annoying is it!!! only wheel locks grrr!!!!!!!!!!
Although im kinda confused...Drums on a Gtst???????..am i missing something here :happy:
yeah for the handbrake,inside the rear disc.
seriously, try nissan. you may be surprised, particularly if it shares with a local car.
yeah for the handbrake,inside the rear disk
Well bugger me sideways i had no idea...I was thinking of an old set of holden drums i changed once..are they same sort of principle i guess,,
guess ill see when i try fix my busted rear stud
Sorry to hi-Jack but if I go hydro handbrake can I leave these off my car?
Cheers
Sure can.
:ermm:
sure will....its kind of a funny setup, I haven't seen it on other cars except nissans from the period
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
