  • Replies 42
Item ☆: HNR32 Autech RB26 NA
Manufacturer ☆: Nissan Autech
Vehicle ☆: HNR32 Otekkubajon
And wound ☆: I blow the engine.
☆: Head Missing you think. We do not have more roses do not know.
For used goods ☆, thank you no claim no return.
Pretty much just for parts
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5236830
Lol unless you stop and chat to everybody they won't know its a rare engine, but they'll certainly know how fast/slow it is :blush:
Could you whack on a turbo if u lowered the compression? I'd be interested in these engines if you could
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5242865
Your f***ing kidding right?
You know what you would have then? A rb26.
Geez.
Edited by R33_Dude
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5243275
No matter what you do a turbo is the best mod for more power, and to your second line... "look at me i have the non turbo version of the bugatti vyron (or however its spelled) im so cool coz its rare... but honestly iv got to be fu*cking kidding right? without those turbo's and related mods its only 200hp hahahahhahahaha
Edited by R34 -_-
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5243787
Your totally missing the point: why would you turbo it when for an equivalent price you could have an actual RB26DETT. In other words why bother?
Also outright power isn't the point of an N/A engine: its response, tractability, and the power/torque curve.
Would be interesting for an na+t setup - keep the high comp pistons etc and put a low boost setup.
It would definately haul at low RPMs with out sacrificing response.
Yes it would be interesting, I imagine the result would be comparable to 2JZGE+T's.
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5244835
How is it different to everyone else doing a + t on all the other na cars? almost every other sports car from the same era came with a turbo model. all im saying is that if you want more power (who doesn't) put a turbo on it autech rb26de+t :D
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5245073
How is it different to everyone else doing a + t on all the other na cars? almost every other sports car from the same era came with a turbo model. all im saying is that if you want more power (who doesn't) put a turbo on it autech rb26de+t :)
Right.
I am assuming now that your a bit thick. So I'll spell it out slowly and carefully just for you seeing that everyone else seems to know whats going on.
Engine 1) Autech RB26DE, same compression, no turbo, more expensive than a RB26DETT
Engine 2) RB26DETT, same compression, twin turbo, less expensive than the Autech
It costs more and is cheaper to just f**king well buy a proper RB26DETT in the first place and not have to f**k about with god damn routing lines and manifolds and all the other bulls**t.
WHY WOULD YOU BUY AND TURBO AN AUTECH RB26?!?!
ANSWERS TO ABOVE RHETORICAL QUESTION (as in it didn't need answering but you know what 'cause your slow I'll answer it anyway): If you bought an Autech you wanted rare. And if you bought an Autech instead of a GTR your not going to turbo it. 'Cause if you did you would be a grade a cock smoker because you could have bought an equivalent GTR for less money.
OR
You got an Autech RB26 for a pittance, for absolutely sweet f**k all.
Does that answer your question as to why you would and wouldn't turbo an Autech RB26?
Edited by R33_Dude
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5245339
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
