  • Replies 42
Item ☆: HNR32 Autech RB26 NA
Manufacturer ☆: Nissan Autech
Vehicle ☆: HNR32 Otekkubajon
And wound ☆: I blow the engine.
☆: Head Missing you think. We do not have more roses do not know.
For used goods ☆, thank you no claim no return.
Pretty much just for parts
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5236830
Lol unless you stop and chat to everybody they won't know its a rare engine, but they'll certainly know how fast/slow it is :blush:
Could you whack on a turbo if u lowered the compression? I'd be interested in these engines if you could
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5242865
Your f***ing kidding right?
You know what you would have then? A rb26.
Geez.
Edited by R33_Dude
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5243275
No matter what you do a turbo is the best mod for more power, and to your second line... "look at me i have the non turbo version of the bugatti vyron (or however its spelled) im so cool coz its rare... but honestly iv got to be fu*cking kidding right? without those turbo's and related mods its only 200hp hahahahhahahaha
Edited by R34 -_-
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5243787
Your totally missing the point: why would you turbo it when for an equivalent price you could have an actual RB26DETT. In other words why bother?
Also outright power isn't the point of an N/A engine: its response, tractability, and the power/torque curve.
Would be interesting for an na+t setup - keep the high comp pistons etc and put a low boost setup.
It would definately haul at low RPMs with out sacrificing response.
Yes it would be interesting, I imagine the result would be comparable to 2JZGE+T's.
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5244835
How is it different to everyone else doing a + t on all the other na cars? almost every other sports car from the same era came with a turbo model. all im saying is that if you want more power (who doesn't) put a turbo on it autech rb26de+t :D
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5245073
How is it different to everyone else doing a + t on all the other na cars? almost every other sports car from the same era came with a turbo model. all im saying is that if you want more power (who doesn't) put a turbo on it autech rb26de+t :)
Right.
I am assuming now that your a bit thick. So I'll spell it out slowly and carefully just for you seeing that everyone else seems to know whats going on.
Engine 1) Autech RB26DE, same compression, no turbo, more expensive than a RB26DETT
Engine 2) RB26DETT, same compression, twin turbo, less expensive than the Autech
It costs more and is cheaper to just f**king well buy a proper RB26DETT in the first place and not have to f**k about with god damn routing lines and manifolds and all the other bulls**t.
WHY WOULD YOU BUY AND TURBO AN AUTECH RB26?!?!
ANSWERS TO ABOVE RHETORICAL QUESTION (as in it didn't need answering but you know what 'cause your slow I'll answer it anyway): If you bought an Autech you wanted rare. And if you bought an Autech instead of a GTR your not going to turbo it. 'Cause if you did you would be a grade a cock smoker because you could have bought an equivalent GTR for less money.
OR
You got an Autech RB26 for a pittance, for absolutely sweet f**k all.
Does that answer your question as to why you would and wouldn't turbo an Autech RB26?
Edited by R33_Dude
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5245339
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
