  • Replies 42
Item ☆: HNR32 Autech RB26 NA
Manufacturer ☆: Nissan Autech
Vehicle ☆: HNR32 Otekkubajon
And wound ☆: I blow the engine.
☆: Head Missing you think. We do not have more roses do not know.
For used goods ☆, thank you no claim no return.
Pretty much just for parts
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5236830
Lol unless you stop and chat to everybody they won't know its a rare engine, but they'll certainly know how fast/slow it is :blush:
Could you whack on a turbo if u lowered the compression? I'd be interested in these engines if you could
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5242865
Your f***ing kidding right?
You know what you would have then? A rb26.
Geez.
Edited by R33_Dude
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5243275
No matter what you do a turbo is the best mod for more power, and to your second line... "look at me i have the non turbo version of the bugatti vyron (or however its spelled) im so cool coz its rare... but honestly iv got to be fu*cking kidding right? without those turbo's and related mods its only 200hp hahahahhahahaha
Edited by R34 -_-
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5243787
Your totally missing the point: why would you turbo it when for an equivalent price you could have an actual RB26DETT. In other words why bother?
Also outright power isn't the point of an N/A engine: its response, tractability, and the power/torque curve.
Would be interesting for an na+t setup - keep the high comp pistons etc and put a low boost setup.
It would definately haul at low RPMs with out sacrificing response.
Yes it would be interesting, I imagine the result would be comparable to 2JZGE+T's.
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5244835
How is it different to everyone else doing a + t on all the other na cars? almost every other sports car from the same era came with a turbo model. all im saying is that if you want more power (who doesn't) put a turbo on it autech rb26de+t :D
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5245073
How is it different to everyone else doing a + t on all the other na cars? almost every other sports car from the same era came with a turbo model. all im saying is that if you want more power (who doesn't) put a turbo on it autech rb26de+t :)
Right.
I am assuming now that your a bit thick. So I'll spell it out slowly and carefully just for you seeing that everyone else seems to know whats going on.
Engine 1) Autech RB26DE, same compression, no turbo, more expensive than a RB26DETT
Engine 2) RB26DETT, same compression, twin turbo, less expensive than the Autech
It costs more and is cheaper to just f**king well buy a proper RB26DETT in the first place and not have to f**k about with god damn routing lines and manifolds and all the other bulls**t.
WHY WOULD YOU BUY AND TURBO AN AUTECH RB26?!?!
ANSWERS TO ABOVE RHETORICAL QUESTION (as in it didn't need answering but you know what 'cause your slow I'll answer it anyway): If you bought an Autech you wanted rare. And if you bought an Autech instead of a GTR your not going to turbo it. 'Cause if you did you would be a grade a cock smoker because you could have bought an equivalent GTR for less money.
OR
You got an Autech RB26 for a pittance, for absolutely sweet f**k all.
Does that answer your question as to why you would and wouldn't turbo an Autech RB26?
Edited by R33_Dude
https://www.sau.com.au/forums/topic/320334-na-rb26-autech/#findComment-5245339
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
