Hi guys,
Been doing a little research into turbo options for an RB30 and the GT3582 can be had with anti-surge cut into the intake shroud, which I'm assuming is the ports they drill around the shroud to allow air to escape out of the compressor housing back to the intake to alleviate surge etc, e.g. if the turbo is making more boost than the engine can flow (for whatever reason, e.g. throttle closing etc), any excess pressure that would normally cause a surge escapes through the shroud, is that right?
BOV's as far as I'm aware are designed to relieve pressure between the turbo and the throttle plate when the plate snaps shut, preventing the compressor working against a charge of compressed air that ain't going anywhere.
Now, my question is..... does having an anti-surge shroud effectively negate the need for a recirc/blow-off valve, since the air will have somewhere to escape when the throttle snaps shut?
Is anti-surge even worth it? I heard it can lead to *slightly* delayed pressure rise etc (without affecting spool time directly) but the benefits are that you won't kill your turbo (or engine) if you encounter surge conditions.
Can anyone shed some light on this? I'm interested in knowing more about surge in general, what can cause it in a setup and whether the preventatives measures are worth the extra cost and tuning consequences (if any) etc......
Cheers guys.
https://www.sau.com.au/forums/topic/320351-question-about-anti-surge-and-bovs/
Anti surge is designed for the ramp up onto boost - stopping the compressor hitting the surge area on throttle coming up in the lower (left hand side) of the turbos comp map.
It won't have the same effect off throttle where the BOV comes into play and certainly wont pass the volumes in terms of air a BOV will.
You will still get the typical flutter/surge if you come off throttle with a anti-surge housing as that is not the cause they were designed to stop :D
Ah ok, so you mean anti-surge is designed to prevent the turbo surging in conditions where it's capable of *increasing* the flow rate faster than what the engine can flow at a given RPM?
I've been reading compressor maps for the GT35, GT40 etc.... doing my head in trying to work out the best selection for a nice responsive RB30 that'll still make decent power... I know a lot of people have said the GT35 is a good match, but I'm keen to figure out what figures it can do *within* the 76-79% efficiency envelope. I'm sure there's a lot of people out there who have slapped a big turbo to their car and wound up the boost without considering compressor maps etc.....
In terms of using flow rate/pressure ratio to determine what HP a turbo will support, how do you apply that logic to calculating engine HP? Is the HP figure for a turbo (e.g. 40lbs/min equates to 330hp etc) just added on to the N/A equivalent horsepower of an engine?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
