was wondering if anyone has the dimensions from Hub to Hub and front to rear for the R33 or R32 rear subframe/suspension. from what i gather the GTR and GTST are dimensionally the same so either is fine.
not going to give away too much as to what its for at this stage but if anyone has one removed from a car atm or knows offhand where i could get them etc it would be great
this can be either at full droop/full compression or ride height
Cheers
  • 3 weeks later...
can anyone confirm that R32 GTR and R33 GTST are interchangeable ?
know that GTR rear ends have been used in R34's but if the mount points are the same from R32 GTR and R33 then i can jig around a cheap bare 32 subframe.
  • 2 months later...
The R33 subframe mounting points are offset by 5mm each towards the outside of the car. The anti-squat geometry is modified by lowering the front pickup point of the lower control arm by 15mm or so. (Off the top of my head; haven't measured that bit)
I have a jig for skyline subframes front and rear. It's fairly specific for the chromolly tube subframes I do but your welcome to take basic measurements of it. Mounting locations etc are all factory.
I won't send it anywhere and i don't want the geometry/pick up locations measured though as it has taken me alot of time, experiance and money to get right.
  • 4 weeks later...
  • 3 months later...
these measurements are from the middle of the bolt hole:
r32/s13
width
605mm
1070mm
length
665mm
r33
width
615mm
1085mm
length
655-660mm
i couldn't get the lengths exact with the hoops in the frame getting in the way
  • Like 1
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
