regretfull sale but cannot afford it and dont have the time anymore for it :D
a R32 gts-t with a rb25, Black, body is not 100% few scratches around n stuff, all 4 guards rolled/ pumped and in primer, the 2 front guards are in pretty bad nick but am in the process of hunting down some new guards for it atm, the car comes with side skirts and a front bumper (im pretty sure its vertex) all you need is a rear bumper (side skirts and front bumper not fitted atm)
the jack rails have been pushed up on both sides and crushed, however it has passed regency and they did not seem to have any issues with it. most of the engine parts are literally under 100kms old, basically had its 100,000kms service (water pump, timing belt ect). had a new rb20 gear box put in it at the end of 2007 when i first brought the car.
chasis has done 175,xxx kms, new engine has 76,xxx on it when i brought it (only done 100kms since its been in there)
The car came up to 243rwkw on 17psi.
car currently has this set up:
R32 skyline
Engine:
RB25 Conversion
Hypergear Hiflow with ATR43 .63 rear housing (capable of 300+rwkw)
50mm External Wastegate with screamer
split dump pipe with straight through exhaust with cannon on the end
Saber front mount intercooler
50mm Dual Core aluminium radiator with twin thermos
HDI dual stage boost controller
New exhaust manifold studs/gasket, turbo to manifold gasket, oil drain gasket, turbo to dump pipe gasket
Drift brand pod filter
Remaped RB20 ECU to suit rb25
Solid engine mounts
Bosch 040 fuel pump with new fuel filter
Exedy GTR Clutch
ISC oil cooler
Oil temp, oil pressure, water pressure and boost gauge
All air conditioning removed
Nulon Street and track oil.
Tectaloy 100+ coolant
New water pump
Adjustable ex cam gear
Gates timing belt
Metal exhaust manifold gasket
Water temp, oil pressure, oil temp guages in car
Suspension:
Dish steering wheel
Racing logic coilovers
Tie rod ends
Castor rods
GTR rear swaybar
Nismo 2-way diff
Hicas lock bar with hicas removed
Lenso D1R Project D wheels (17x10 +15 offset)
Neuton 5000s on rear Kuhmos on front
Bendix Ultimate brake pads
Interior/body:
Rolled/Flared guards
Passenger adjustable bucket seat
Removed spare wheel, jack ect in boot
rear seats removed
Front bumper/ side skirts
Blue dash lights
Pioneer CD player/ pioneer speakers all around
most stock parts such as hicas, stock intercooler, full A/C in back shed, castor rods, tie rod ends, sway bar, diff, rear seats, rb20 turbo, ect. come with the car
i also have about 500mls of paint for it that was spare from when i got bumper painted
ring me or pm me on 0428851616 for pictures, Located in South Australia
$10500 or $9500 without the rims...interested in swaps for a daily or something along those lines...nothing turbo. cheers
https://www.sau.com.au/forums/topic/320367-r32-with-rb25/
have something that may go unnoticed if the turbz is a cop thing or if its fuel just go low boost :) heres link GTIR
haha nar i dont want a turbo car anymore, cbf with em. cheers though
https://www.sau.com.au/forums/topic/320367-r32-with-rb25/#findComment-5263145
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
    • I think even the "commercial" capacity ones that you would hire from supermarkets etc wouldn't have the capacity to do all that much in one go. I will go through half a dozen tanks of solution and dumps/rinses of the waste tank for one little 2 seat sofa. Or similar for one 6 footish rug. That's the price you pay for something small that only takes up a bit of cupboard space, instead of something that takes up the entire laundry cupboard or half the shed.
