Have the following for sale. All items are negotiable and located in Ipswich.
Item: 6boost Rb26 manifold - to suit TV flanged turbo's, 50mm wastegate pipe, made for a 26/30 in a 32 gtr so it sits the turbo forward of the shockie tower so theres room for a 5" dump
Condition: Brand new
Price: $900
Item: Argo RB30 21mm conrods
Price: $950
Item: Aeromotive Pro Series fuel regulator
Price: $350
Item: RB30 block & custom 4wd Billet Girdle.
Condition: New & used
Price: $1900
Comments: Block is std bore, it's been modified to suit the billet girdle (no oil pickup, de-burred and has been clearanced around the sides to bolt a 4wd sump)
Will you ship to Canada ??
Cant pm you as I do not have enough posts !!!
I can, but shipping would be be expensive.
Also the manifold and rods have sold.
hey bud... i already have an rb30 bottom end that has had EVERYTHING known to man done to it for a 26/30.. but it was built for my old car which was only going to be rear wheel drive..
now i want to convert that motor back to 4wd and was wondering where u got that girdle from??
and also why does it eliminate the oil pickup?? is it for a dry sump setup only??
thanks
thanks
The girdle i made and designed myself. I made 1 for a rwd rb30 and the one i have, for a 4wd rb30.
Reason it eliminates the internal oil pickup, is because i did not want to weaken the centre main cap by remove excess material from that area. Plus if your going to be building a big engine like that, you should atleast go external oil pump, if not dry sump.
Hey i think Rips does billet girdles, goodluck
That he does, but his a multi-piece system, mine is an all-in-one :D
well let me see what i can do.. i might be very keen on this... is the crank standard size??
big end and main??
  • 1 month later...
Girdle is sold. Only have fuel reg left.
Also have 2 of my 4wd adapter plates for $500 each.
    • The GTT probably only has the same little bag of tools that the R32 had, which contained useless pliers, a spanner or two, a screwdriver thingo, and the handle and crank stuff for the jack.
    • ? 2s of searching finds this thread
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
