Hey Mark!
drag racing every wednesday night at WSID
drifting is now done at wakefield, EC skid pans and sometimes WSID car park.
projectD is a good site to check out for drifting. you can even use their cars!
Otherwise for track days SAU NSW has a wakefield day in July.
We also hold motorkhana's called "texi's" and these are all for new and old drivers in any car in a controlled environment which is 100% LEGAL!!
best to join the club, get ya CAMS licence and do some days with us!
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5229740
Hey all
i've just moved to sydney from tas and Im wondering what drift tracks and drag strips are here and how do I get involved etc?
the only place in sydney to drift
see the link
http://www.skylinesaustralia.com/forums/Tw...4t-t318897.html
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5229761
Thanks very much for your help guys cant wait to get amongst it.
I've just finished off my rb26dett engine conversion in my 32 (built and tuned by JPC in melbs)
Spent a bloody stupid amout of coin on this engine but havn't had a chance to get it back out on the track with the new setup as yet
Just in the process of geting my car shipped over from tas atm so look forward to geting out there very soon.
Oh and by the way how are the cops over here with modified cars? Or is that a silly question?
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5229831
The cops over here are great.......as long as they DONT see the car or look under the bonnet you shouldn't have a problem. LOL
sorry I couldn't resist
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5230623
Hey Mark!
Unfortunately no drift days have been held there yet and apparently it won't be going ahead anymore, complaints have ALREADY been made about the idea and it looks like nothing will be happening at the carpark anymore.
Barely any drift days are held at Wakefield anymore aswell, but Eastern Creek have corners 4-12 available to drift on about once a month or so with the club DrivingSports.
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5230728
So in all honesty how bad are the police?
My car has not been engineered with the new engine twin turbo combo and will retain the tas rego for as long as possible.
It has a uras kit with 17x10's all round so the wheels do hang out the gaurds slightly? Im living in manly vale area.
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5230830
An aggressive body kit and wheel stance is always going to grab attention no matter where you live.
My advice, drive it like it puts out 3kW and keep it away from Manly, especially on the weekends :P
https://www.sau.com.au/forums/topic/320373-where-to-drift/#findComment-5231443
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
