Hi man
I think i have one of these
U are wanting the conecter that clips onto the lamp amd the short wiring piecethat joins the headlight and the high beam together.
is this right
stuart 0409135950
Hi man
is this right
stuart 0409135950
thanks for the response.
yep thats exactly what im after.. there are two headlights (projector type) that fit the r32 skyline.. one takes a h3 bulb and another takes a h3c bulb.
i got a hid kit for my car only to discover that the drivers side headlight to my car is a diff model and only has the h3 holder so the headlight is pointing in a funny direction (cause the bulb isnot in its proper place).. hope all that explains a bit more of what im after.
just trying to make clear the diff btwn h3c and h3 bulb (and their holders) just to make sure im not putting you through all this only to recieve the same holder i have in me car..
cheers, tushar
Hi man
In all r32 gtst and gtr there are 4 types of globes
h1 is a single pin spade conection and requires a black adapter to conect to wiring loom [low beam only]
h3 is a simmilar lamp but has a short piece of wire soldered to it and has spade terminal on end [low beam only]
h3c is once again a simmular lamp but has 2 spade connection terminals at the base of the globe [low beam only]
nh4 is a low and hi beam lamp that has 3 spade conection on it's end
Please let me know which lamp you need parts for and i will pick the right one and do u need both sides or only one
stuart 0409135950
Ɨ
Ɨ
