Selling an HKS 2535 turbo with HKS snail dump
Very good condition, compressor + exhaust wheels are perfect & spin freely
Direct bolt-on upgrade for RB20 & 25
These turbos are rated around the 400hp mark from memory
$1400 ono
Edited by endless
https://www.sau.com.au/forums/topic/320384-hks-2535-turbo-whks-dump/
How old and roughly how many kms travelled or was this on a fresh import with unknown history
(as these have been discontinued for quite some time now...)
yes I'm interested in purchasing...
Yeah not too sure mate.. It came off an R32 in japan that was parted out.
Reported running perfectly before part out and only tuned to 1 bar. Couldn't have had a lot of use going by the condition of it.
Was going to use it myself but i'm selling my car.
Edited by endless
price? and is the exhasut outlet same as rb25?
thanks
simon
dude price is under the pics.
$1400, Bargin. If this is around in a few weeks when i have the cash. I will buy it.
Exhaust is the same pattern as rb25
hi mate
keen to swap with my R34 turbo engine?
refer to this: http://www.skylinesaustralia.com/forums/Fs...p;hl=long+block
let me know, as im keen on your turbo.
cheers.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
