ENGINE: *CP pistons
*Eagle rods
*Jun oil pump
*Tomei sump baffles
*Tomei headgasket
*Tomei oil feed restrictors
*custom oil drian from the rear of the head to the sump
*balanced crank
*acl race bearings throughout
*N1 water pump
*Apexi cams ( not sure what lift)
*Hks cam gears
*Hks timing belt
*Bigger Fuel pump
*700cc sard injectors
*adjustable fuel reg
*Nisstune ECU
*twin Garrett -5s
*Huge intercooler
*Alloy radiator
*Front sway bar
*middle sway bar ( in photo of interior)
*rear sway bar
*Bilstein coilovers
*torque split controller( not working at the moment will try to get fixed before sale)
*drilled rotors
*gauges, oil pressure, boost
*Alpine headunit
*Alpine 6x9s
*oil filter relocation kit
*Engineers certs prob other stuff to but cant remember everything. The car also comes with the standard gtr spoiler and Nitto Extreme drag semi slicks for the rear. Car made 340kw on 18psi with a power fc on a safe tune and made 450kwatw on 23psi, it now makes closer to 300kw with the nisstune in it, the power fc was taken out after police trouble in melbourne, which is where the car was built and made that power, if you want to ask the work shop any questions, prob should call me first jus so i can let them no what car, Ice Performace is the workshop that built it
$21,000
0411794280
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/
i thought they didnt exist any more?
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5229808
450 kw on 23 psi ??...sounds like a very happy dyno.
Good luck with the sale though,some nice parts on there..just the dyno figures seem a bit unrealistic .
Edited by ezy_09s
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5236439
so would you be up for a dyno test befor buying ?????? i dont care if i pay but i want to pick the place
Yea man sure, sorry i took a while 2 reply but i don't hav the net @ my place, jus ring me 2 set up a look c, on 0411794280
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5243006
yea i no, dats wat ice performance told me. Although the boost may hav bn higher i cant remember, prob more like 26 27 id say!
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5243023
Hey guys just letting u no that i was missinformed by the previous owner and the car made 454kw on 27psi with the nisstune. It also has a N1 oil pump not a Jun, as well as aftermarket valve springs and a recond head gbox and diff.
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5256427
  • 3 weeks later...
Bump
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5290601
  • 4 weeks later...
Where are you located mate I'm interested?
he's located in Lismore, far north coast of NSW. and he lacks having internet at home which is why his responses are sometimes non-existent.
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5400869
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
