yeah difference is minor. the HKS ones seem to have a little more power potential and response difference is negligible. I prefer the HKS ones but I admit it's hard to justify the price premium over the generic ones for what you get. the good thing with the HKS ones is they come with good actuators, fasteners, gaskets etc. some garret retailers add cheap gaskets with their kits, some add good ones and some add none at all so when pricing kits you need to check what exactly you get for you money. some 'kits' are just 2 turbos completely bare (ie not even actuators included).
I made 467kw at the treads under strict dyno competition conditions (real figures) with these puppies years ago when that was spastic power and ran 10.3's on radials in a 1570kg car...try doing that with your Garrett's.
Edited by Swiper the Fox
Owned ;)
Im glad you picked that example Steve-o...as i know quite a bit about it.
haha...the car he used for his example doesn't in fact run -5's. I spent a week with Ben at his Melbourne workshop 18 months ago and he assures me they are not your run of the mill -5. He actually tested 8 different turbo combo's (changing trim, housing etc) before finding out what worked best. To avoid someone copying them he orders the bits from different suppliers and performs the assembly in house (JFK's post on the last page was very close to the mark but slightly inaccurate). Ive been for a drive in this car and experienced it first hand...Ben admits the amount of r&d gone into just the engine bay would exceed over $200,000.
Makes the 2530's look like a real bargain now doesn't it.
Thanks mate. :)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
