Guest Sinon
The time has come to let her go after 5yrs of love and respect.
Nissan Skyline R32 GTR 1994
3 layer Pearl white
Koya !8"x9.5" wheels with 245 an 275 rubber
Nismo Carbon clutch
Apexi Avcr
Tein SS suspension
Awesome Alpine DVD sound system
3" SS awesome sounding exhaust
$22,500
More details on request
Call Steve on 0403 541 636
https://www.sau.com.au/forums/topic/320512-r32-gtr-94/
hey how many ks? and another major mods?
3 layer Pearl white
Nismo Carbon clutch
Apexi Avcr
Tein SS suspension
$22,500
https://www.sau.com.au/forums/topic/320512-r32-gtr-94/#findComment-5242811
  • 5 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
